i rang camtech in Sydney they told they are willing to to a regrind for me, i just have to send a set of cams down to them so they can see what sort profile they can do. now i just have find a second engine.
  • 4 months later...
  • 3 weeks later...
Lol. I sold them to him from my car. He was a bit iffy at first but in a short time he loved the look :)
yeah, it seems everything gtr was made for a 180sx upgrade.
since the brake and driveline upgrade, i've bought a second engine that had water in one of the bores to make the cams with. i since spoken to kelford cams in nz who where more helpful than camtech. kelford said they would test the cams for defects and then make a decision of how much they can grind them and to what duration. where camtech said they don't do that and i must tell them how to grind.
i'm also going to use the second engine to test engine internals from other cars to see sr20 rods fit and that the arp rod bolts and head studs fit and if sr20 cam cap bolts.
If your going na power, some guys in the states are looking at going with Honda rods and motorcycle short skirt pistons.... Shedding kilos of rotating mass. Might be worth looking at?
... On a serious note though, Jim wolf have done a lot of testing with vh cams.
Are we likely to see some short velocity stacks under that cowl? Maybe a little gas?
J.
got the old r32 brake master cylinder replaced today, swapped with a brembo spec r33 gtr master.
top one is the old r32 spec 15/16 bore and the bottom is the installed brembo r33 bm57 1-1/16 bore.
pretty much instant braking response now, just have to worry about the daydreaming idiots behind me now. (well...more so)
One of the SAU Traders Halfod Motors has new BM57 (e.g. 17/16 bore) master cylinders in 2 and 3 port models for $149 and $139 delivered free.
This is much cheaper than buying a second hand one and then trying to get a kit to recondition it
Thanks Charles,
I pretty much came to that conclusion after my own searching tonight! The BM50 would probably be better, but runs a hefty price as a non abs.
Being a rps13, mine has a bm44, so it's better than the early models bm33, but I don't think they are up to the brembo fronts and twin piston rears.
So I think I might give the 57 a go- cheap and easy to get in Non abs.
Actually splits the port via a tee to both front wheels, rear is single line to the back and splits at the back :D
So bias is set as per factory for front to rear.
He just needs to source a new connector plug to suit the BM57 reservoir (as they are different manufacturers) so that the low level warning light works.
  • 3 weeks later...
yesterday and today we started doing some over due maintenance on the vh45, new injectors and replacing the leaking rocker cover gaskets. the old injectors were so old they gone white, this should make it run smooth as silk.
new injectors, nissan wanted upwards of $400 each for them i managed to buy them on ebay for $400 total from america
one of the new injectors was dead, not happy but at least it was number one cylinder and can be removed with out taking off anything else. We put one of the old injectors in instead, luckily it seems we managed to find one that's not miss firing. ordered two more to be safe.
I like how u say we, when its really just sean :P
  • Like 1
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
