i rang camtech in Sydney they told they are willing to to a regrind for me, i just have to send a set of cams down to them so they can see what sort profile they can do. now i just have find a second engine.
  • 4 months later...
  • 3 weeks later...
Lol. I sold them to him from my car. He was a bit iffy at first but in a short time he loved the look :)
yeah, it seems everything gtr was made for a 180sx upgrade.
since the brake and driveline upgrade, i've bought a second engine that had water in one of the bores to make the cams with. i since spoken to kelford cams in nz who where more helpful than camtech. kelford said they would test the cams for defects and then make a decision of how much they can grind them and to what duration. where camtech said they don't do that and i must tell them how to grind.
i'm also going to use the second engine to test engine internals from other cars to see sr20 rods fit and that the arp rod bolts and head studs fit and if sr20 cam cap bolts.
If your going na power, some guys in the states are looking at going with Honda rods and motorcycle short skirt pistons.... Shedding kilos of rotating mass. Might be worth looking at?
... On a serious note though, Jim wolf have done a lot of testing with vh cams.
Are we likely to see some short velocity stacks under that cowl? Maybe a little gas?
J.
got the old r32 brake master cylinder replaced today, swapped with a brembo spec r33 gtr master.
top one is the old r32 spec 15/16 bore and the bottom is the installed brembo r33 bm57 1-1/16 bore.
pretty much instant braking response now, just have to worry about the daydreaming idiots behind me now. (well...more so)
One of the SAU Traders Halfod Motors has new BM57 (e.g. 17/16 bore) master cylinders in 2 and 3 port models for $149 and $139 delivered free.
This is much cheaper than buying a second hand one and then trying to get a kit to recondition it
Thanks Charles,
I pretty much came to that conclusion after my own searching tonight! The BM50 would probably be better, but runs a hefty price as a non abs.
Being a rps13, mine has a bm44, so it's better than the early models bm33, but I don't think they are up to the brembo fronts and twin piston rears.
So I think I might give the 57 a go- cheap and easy to get in Non abs.
Actually splits the port via a tee to both front wheels, rear is single line to the back and splits at the back :D
So bias is set as per factory for front to rear.
He just needs to source a new connector plug to suit the BM57 reservoir (as they are different manufacturers) so that the low level warning light works.
  • 3 weeks later...
yesterday and today we started doing some over due maintenance on the vh45, new injectors and replacing the leaking rocker cover gaskets. the old injectors were so old they gone white, this should make it run smooth as silk.
new injectors, nissan wanted upwards of $400 each for them i managed to buy them on ebay for $400 total from america
one of the new injectors was dead, not happy but at least it was number one cylinder and can be removed with out taking off anything else. We put one of the old injectors in instead, luckily it seems we managed to find one that's not miss firing. ordered two more to be safe.
I like how u say we, when its really just sean :P
  • Like 1
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
