yeah engine looks a bit crowded, the result of putting that huge filter in is staggering. I've seen a few posts on other forums in the US complaining that the vh45 power band flat lines above 5000 rpm. I had the same issue, a massive decline in the rate of acceleration. apparently a 12in long 6in round filter does the trick. who would of thought. now we just have put an air box around it.................some how.
on another note, Sean said me he talked to the BMC filter guy at the stand at super-lap on Saturday, and told him his filters suck :spank:. I wonder how that went down. they said the biggest enclosed air filter they make only has a 100mm insert.
I put it nicely to them that it was restricting the engine, as this 4.5L with the factory 90mm intake @7000RPM would be ingesting 'x'litres of air! The BMC filter canister unit that we originally fitted had an 80mm intake, and enough filter cross section for an engine half the size...
So that's why it was flat-lining after 5000RPM, not enough airflow at the higher RPM's. The 80mm intake was my first guess why it was a restriction. So much better now, it sounds completely different, with so much filter area available now.
As said before they do have a 100mm intake adapter that is meant for a honda S2000, but the filter element itself would still be a restriction. Could run 2 filters, but there isn't enough room, and cost is up there.
turns out that Ross tuffbond balancer i got made is a $900 paper weight. its not even close. the standard balancers have 3 pulleys i needed the second pulley only as i only run a water pump and alternator of the same pulley. they made it with the first pulley and then it's the width of the second, so nothing lines up. not happy again, why is good help too hard to find! it probably even won't bolt on, 7 months for a balancer that they just winged. :rant: really angry!!!
turns out I'm an idiot, the balancer was made to sit spaced out from the engine block. so it does line up there just will be an air cap of an inch between the engine and the start of the balancer. crisis over.
the 450sx now has a digital climate control from a type x, we needed to rewire the 3 plugs for the analog one in to 2 plugs for the digital one. that and it's running close to 19 degrees of timing now, it was running 17 degrees factory... seems a little hi but apparently the factory setting are 15 +/- 2 so 17degrees is the limit so it works. the question is should i put cams in it?
Josh, at the end of the day... was the vh45 swap worth it??
hell yeah, i was just going to put a rb26 in it when the ca original went but really wanted something different. but after it's all been said and done. I'm really glad i did this conversion, i really can't get enough of how this car drives now, the chassis has come alive. unlike the turbo it's all up to my right foot and i love that.
this. :thumbsup:
very nice work mate.. it does have a tough corvette muscle look to it imo.
i'd love to see this thing in action, forgive me i did skim through the thread.. any vids??
listen out for Steve's comment at the end
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
