I just done the OP GP and was hearing 2-3 engines have failed. That's 5% of the cars. Now since returning from the track day im hooked and now looking for my next track day. However anyone who is running a modified engine will always have in the back of their mind "will my engine fail because of the oil". I plan on doing more track days in the near future but is it worth pulling the head off and opening up the oil galleries and putting in the restrictions. How much do workshops ask $$ wise for this type of job. Or do i just wait for the bearings to fail then rebuild it with forgies and put the oil mods in at the same time. i know that to do all the oil mods the engine will have to come out. If i can help it i really dont want to ever rebuild my engine (not looking forward to a 10k engine rebuild), but rather take preventative measures. i did overfill it by 1 liter on the track day and installed an oil cooler but that's all i can do atm.
In the near future the car will be tuned for around 270kw if that matters.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/
  • Replies 41
270rwkw on what turbos?
with that much power, as long as you overfill the sump by 1ltr you should be perfectly fine.
A stock RB26 wont last forever regardless if your tracking it. It'll last a year, maybe 3... but ye - most have not lasted forever unfortunately.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4662126
tough decision... to do the oil control mods properly it means modified sump (and oil galleries etc) so is an engine out job... to drill the oil galleries will require the block to be stripped and cleaned and put back together with new bearings etc... To do all that is going to cost you several thousand dollars... and while its out you may as well get a new high flow oil pump and check the pistons etc... you may end up replacing piston rings and maybe even the pistons themselves depending on condition... then there is the head which while off you may want to check clearances etc... also a new set of gaskets, studs blah blah will be needed to put it back together... soooooo before long you will have spent over 5K just on 'preventative' measures and maintenance
I reckon you just keep overfilling it, keep the rev limit sane and start saving for a full rebuild down the track... hopefully you get a few years out of it before it cries enough... you WILL be needing a rebuild at some point with regular track work but how long you get is anybodies guess... if it aint broke don't fix it!
oh are you running the standard ceramic turbos? if yes you will want to swap them out when you pull the motor to do oil control mods
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4662160
im running hks 25/40 turbos so they are steel wheels. Holy crap didn't think preventative measures would cost that much. How the hell did Nissan build such a good car and F#@k up the oil part. From what you guys are saying from 50 cars that start the track day, an average of 1-2 will die is the norm. Now that sucks. Oh and now i know why my 3 instructors were trying to get me to change gears earlier and not drive to red line.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4662817
remmeber with a 26 if your turn the bearings the crank is toast (most of the time).... they bend like a slinky.
Prevention is far better than cure.
Run an extra litre in the sump and start saving for a build.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4662878
standard - the motors are relatively fine :P.
You could really do with better turbo's if you wanted to track :)
2540's are the black sheep as they make power, but not responsive at all.
But do that once the motor dies.. i mean... if it dies :)
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4662946
Random, uneducated thoughts about what could be risky for oil starvation;
- High revs, especially during long sweeping corners
- High grip suspension/tyres (the oil will be sloshed up the side of the sump harder in corners)
- High volume oil pump (more oil out of the sump more quickly)
- Thick oil (will take longer to drain back down)
So if i were you;
- Overfill the oil to the bottom of the top hump on the dipstick
- Dont use R-spec or slick tyres
- Dont rev too high, maybe change at 7000, and short shift where you cant use full power out of corners. This will be more of a problem with laggy turbos that need revs
- Use a good synthetic 0w-40 or 5w-40 rather than a 10W-60...
Also some people say that adding an oil cooler will help with oil starvation - i'd love someone to explain how that works to me.
Why not PM the guys that lost motors and ask what, if anything, they did to stop/resist oil starvation (assuming the motor wasnt lost to through some other reason)
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4664139
oil cooler doesn't really help with oil starvation directly but it helps keep RB26 engines alive on the track. without one a hard driven GTR will heat it's oil well past it's useable temp. then the oil stops lubricating properly, film breaks etc and it becomes very thin. hence engine failure. the extra volume in the system compounds the cooling advantage too as there is physically more in the system but again doesn't really help with the pick-up getting starved during cornering etc. but it's a must have none the less.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4664384
i think oil coolers are used as it adds another litre or so of oil in the system without overfilling it on the dip stick.
Think about it - that extra oil is not available for the oil pump pickup, because its already been pumped. Coolers make no difference to starvation AFAICT.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4664388
2nd'ed.
You need to add TWO litres if the oil cooler sucks up one litre
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4664525
I was one of the GTRs that did the bigend bearing and i have all the mods BAR the oil return from the back of the head.
Mods done
: Larger sump with tomei sump baffles
: Tomei oil restrictors with returns enlarged
: I over filled on the day
I would say Revs and the frist sweeping turn did me in i was holding it in 4th down the straight maybe 8500rpm or so as my 4wd was playing up and getting power done was more wheel spin the grip lol.
But it still gave up the ghost so i say fit it when it breaks.
https://www.sau.com.au/forums/topic/275132-rb26-oil-mods/#findComment-4664614
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
