On behalf of SAU:SA, we would like to welcome everyone to the launch of SAU:SA, and the first official event of SAU:SA.
We would like to thank Shannons Insurance, Martini Racing, Geof's Garage and Southern HiTech Dyno Tune for all the sponsorship and support in organising the Dyno Day.
The categories will be:
Highest 6 Cylinder Naturally Aspirated
Highest 6 Cylinder Single Turbo
Highest 6 Cylinder Twin Turbo
Highest 4 Cylinder Single Turbo
Highest Other
Wooden Spoon
There will be trophies and suprises on the day too!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/275144-official-sausa-dyno-day-thread/
  • Replies 443
ummm for now yes might bring the s13 down too but ill let you know later on if theres still a spot left and its not broken haha
thanks cara
ok ill put the R33 down for now :)
1) Cara - R34
2) Kye - R33
3) Vu - R33
4) Ruby - R33
5)Krishy -R33
6)Craig - R34
7)Wayne -R32 GTR
8)Lee - R33
9)Adrian - R33
10)Ben - R31
11)
12)
13)
14)
15)
16)
17)
18)
19)
20)
Try that Vu ;)
ive got a mate with a legnum a rex and a vr4
i dont know if its easy to drop the shafts in them is there going to be a awd dyno?
no there wont be a awd dyno at this event.
Quick Q.
Is the event just for SAU or will other parties be involved ? Like people from other clubs, forums, of the street etc. ?
for the mean time it will be open for SAU people, and then i will re visit the situation on entrants. and the end of the month, and then consider posting on other forums, however, if someone from PGASA wants to be part of the Dyno Day in the mean time, they just need to send me a PM letting me know and ill write their name down on the list :)
1) Cara - R34
2) Kye - R33
3) Vu - R33
4)Ruby - R33
5) Krishy - R33
6)Craig - R34
7)Wayne - R32 GTR
8) Lee - R33
9)Adrian - R33
10)Ben - R31
11)Chad - R32
12)
13)
14)
15)
16)
17)
18)
19)
20)
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
Ă—
Ă—
