Cara, you should know that my car is not a GTST :)
sorry ive noted down the it has rb26 in it so dont worry :P
ill be up for this with the stag if there is sill room i did see two spots left
i am doing a back up list of which you have been placed in, if any one pulls out you will be notified and asked if you would like to fill the position.
also guys can i please be the only one updating the positions please? i dont feel there is a need for 3 people to be doing it
1) Cara - R34 GT (MISSR34)
2) Kye - R33 GTS26TT (IMPORTS13)
3) Vu - R33 GTS25T (TYPEVU)
4) Ruby - RS4 STAGEA (RUBYRS4)
5) Krishy - R33 GTS25T (KRISHY)
6) Craig - R34 GTT (PREISS)
7) Wayne - R32 GTR (WEEZY)
8) Lee - R33 GTS25T (RB25DETS2)
9) Adrian - R33 GTS25T (180OR200)
10) Ben - R31 something T (NUGZY).....
11) Chad - R32 GTS4-26TT (DSTROY)
12) David - R32 GTR (WRITEOFF)
13) Ahmed - R33 GTS25T (MEDMAN2DAMAX)
14) Anthony - R32 GTST (LOVE MY 32)
15) Mitch - R33 GTS25T (DAMAGEINC)
16) Michael - R32 GTR (BREZZA)
17) Ben - R32 GTR (DOHMAR)
18) Penny - Holden SS (ONTHERANCH)
19) Ben - RS260 Stagea (GRIMR32)
20) FOOLBOOST - R33
  • Replies 443
No offence to penny or you cara but I'd rather see 100% skylines and stags, no commodores pls.... 180s and 200's at a stretch..... i doubt anyones really interested in what an ss falcodore pulls
my 2c
-D
my 2c
-D
im with ben on this as it is meant to be SAU,SA
I see both your points, but its a debut event for Skyline and Stagea enthusiasts ... not necessarily owners. The Pulsar club allowed our skylines in on their day (including Mattys smoky truck). I'm sure we can allow one Commonwhore (owned by a Club member) to attend. Due to my broken box in the stag, if all I had access to was a Commie ute, I'd run that on the rollers as well. :)
I see where you guys are coming from, I also agree it should be Stag's and Skylines mostly, but was there not a big argument about this in the thread about the club being Skylines or Stag's only, and came to the conclusion it doesn't matter what you drive, just as long as you are an enthusiast you can participate/join?
Edit - Ruby got to it before me :)
Edited by Aberax
This event is for non SAU:SA Members aswell. It is open to all cars. Hence the categories.
1) Lex - Stagea (YOUWISH)
18) Penny - Holden SS or R34 GT (ONTHERANCH)
20) FOOLBOOST - R33
RESERVE LIST
1) Shane - 350Z (RBWARE)
2) Martin - R32 GTR (HOSTILE)
3) Cara - R34 GT (MISSR34)
4)
5)
6)
7)
8)
9)
10)
Edited by MissR34
Will the runs be happening in this order :D?
Woo full house dyno shoot out. Cant wait.
i will be making sure there is a good mix of cars :D
Battle of the jelly wrestling female 34 NA owners! I'll bring the popcorn! :P
Edited by MissR34
Cara, could John stretch the list to cater for an extra 10 possibly.....some nice rides in that last list over the page...would be a shame for anyone to miss out.
I'll definitely have to re arrange my work to fit in on the day me thinks. (as spectator)
i will ask him pete, but i cant promise anything :(
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
