  • Replies 443
WOW! what a fun filled day!! It was good to meet some people and put faces to their names!
I was the owner of the sky80 and when I rocked up I had no idea I would be rolling on the dyno... other wise I would have cleaned the thing! Tree Sap adds -10rwkwz!
I ended up only running ~10psi.. but stupid me thinking 0.7bar was 13psi (which it can run) and made 142.7!
Too bad there wasn't a trophy for best 4 cylinders Or WORST offset! I wanted to win :(
But thanks to the SAU team for hosting such a good day!
as me and dion discussed black smoke = potential power :P
What a fantastic day today - a credit to the entire SAU SA team that pulled together to make this happen. In my opinion, this was one of the best ran dyno days I have been involved in, and I've been doing them for 10 years!
I agree with Pete, the trophies are awesome - I am very impressed.
A big thanks to John and the crew from Southern Hitech Dyno - they were professional and efficient in keeping the day rolling on with a couple of well earned breaks to clear the lungs of carbon monoxide.....
A big thanks to all involved in organising the event!
Vu - loving the flame action :(
Andrew (Blue32) can you please post up your dyno sheet? I forgot to ask to see it today and would like to see the boost & power curves. Also what GReddy twins are you running?
seemed like a great day for the whole 30min i was able to attend :) stupid work, lucky i was able to squeeze my car in during the lunch break ahaha.
Now all i need is a tune to get rid of the nasty flat spot mid way haha.
great event, nice to see a big turnout of new faces,, and to catch up
I have about 200 photos of the day, and about 95% of the cars put on the dyno have photos so watch this space later today for photos. Hi res will be sent to Nene to put on DVD. or you can PM me for a copy
big thanks to the dyno crew. they really put the cars thru in a timely manner
and the other sponsors and the give aways helped make it feel like a truely professional event!!!!
nice work to all
What a day even though i rocked up late. Very good turn out.
Wish i still put my car on the rollers always next time. But hey i9m glad i gave my spot up to the dyno king. Was a shame i couldnt see that beast on the rollers though.
Looking foward to the next event.
Was also good to see so many new members joining on the day.
Well done to all involved in putting together a very well put on event.
I've wasted about 2 hours of my life on it...
Does anyone know how to convert Newtons to Newton-meter?
my car made 5800 newtons, and i think i've worked that out to 397Nm
Edited by Silhouette31
didnt think there was a difference but here is a handy website
http://www.convertworld.com/en/torque/
Newtons = Force
Newtons * meters = Force * distance = Work = Power
not quite sure how u'd work out the distance the car "traveled" on the dyno =\ im sure there is a way, i just can't be bothered working it out atm =D
The dyno measures tractive effort, so that is 5800N of tractive effort.
You can set up the dyno to show actual engine torque but you ahve to enter all the details like tyre diameter as well as the diff ratio, on a dyno day that isn't going to happen due to time restraints. If you want torque when you car is on the dyno just give the operator the details and ask them to enter them.
Edited by D_Stirls
RESULTS
Highest 6 NA 1st - Cara/MissR34 - R34 - 105.8rwkw
Highest 6 NA 2nd - Martin/Hostile - R31 - 97.7rwkw
Highest 6 Single Turbo 1st - Adrian/180OR200 - R33 - 362.7rwkw
Highest 6 Single Turbo 2nd - Lee/RB25DETS2 - R33 - 331.0rwkw
Highest 6 Twin Turbo 1st - Andrew/Blue32 - R32 GTR - 390.6rwkw
Highest 6 Twin Turbo 2nd - Chad/DSTROY - R32 - 324.1rwkw
Highest Other 1st - Jarrod/FRDH8R - SS - 242.4rwkw
Highest Overall - Andrew/Blue32 -R32 GTR - 390.6rwkw
Best Presented R32 - Chad/DSTROY
Best Presented R33 - Vu/TYPEVU
Best Presented R34 - Damo/ Damo_R34
Best Presented Stagea - Ruby/RUBYRS4
Best Presented Other - Penny/ontheranch
Wooden Spoon Award - Ruby/RUBYRS4 - Stagea
RESULTS
Highest 6 Single Turbo 2nd - Danai/OVRTYM33- R33 - 334.0rwkw
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
