New 2 site, still trying 2 get used 2 it.. That would be good anyhow:)
No worries mate. Just check the dates of the posts your replying too ... normally best to read all pages of a topic if you can, so you're up to speed (tho we're all guilty of it) ... saves for embarrassment, and the thread nazis ganging up on you :D
As for your spot on the reserve list, I'm sure Cara will update the list shortly and let you know if there are any further spots.
  • Replies 443
BUCKLUP - please provide me with your name, and what kind of car you have for you to be added, :D
also guys, John Keen has allowed another 5 more cars into the main group :D
***UPDATED LIST***
1) Lex - Stagea -YOUWISH
2) Ruby- - Stagea - RUBYRS4
3) Krishy - R33 - KRISHY
4) Craig - R34 - PREISS
5) Wayne - R32 GTR - WEEZY
6) Lee - R33 - RB25DETS2
7) Adrian - R33 - 180OR200
8) Vu - R33 - TYPEVU
9) Kye - R33 - IMPORTS13
10) Chad - R32 - DSTROY
11) Ahmed - R33 - MEDMAN2DAMAX
12) Anthony - R32 - LOVE MY 32
13) David - R32 GTR - WRITEOFF
14) Ben - R31 - NUGZY
15) Marko - R33 - SKYHI_33
16) Michael - R32 GTR - BREZZA
17) Ben - R32 GTR - DOHMAR
18) Ben - Stagea - GRIM32
19) Penny - Holden SS - ONTHERANCH
20) Tony - R33 - FOOLBOOST
21) Cara- R34 - MISSR34
22) Pat - VL Calais Turbo - JET30
23) Danai - R33 - OVRTYM33
24) Brenden - Stagea - MRRS4
25) Shaun - R34 - EVIL34
RESERVES
1) Luke - R32 GTR - FISHPASTE
2) Martin - R32 GTR - HOSTILE
3)
4)
5)
Edited by MissR34
RESERVES
3) Jeremy - R32 - RIPP3R
4)
5)
Yay! Im not the only one entering a Holden
Yeah yeah VL has a Nissan engine... it's still a Holden!
Im excited.
Im the only one in a V8 but thats ok....
I'm not entering for the competition or nothing cos its not modded much, just want to see how it will go.
looking at the list, the "other" list, is pretty much Penny and her V8 :thumbsup:
Unless we convince James to get the Honda on... i bet if someone bought their pushbike, they would beat the Honda :banana:
looking at the list, the "other" list, is pretty much Penny and her V8 :banana:
Unless we convince James to get the Honda on... i bet if someone bought their pushbike, they would beat the Honda :P
My Brutale has more hp than that Honda :thumbsup:
looks like im the only 31 there...do i get a prize for highest powered r31?? or lowest powered turbo 6????
ringing hitech tomorrow...not happy with the tune...very unresponsive and ive lost 20kw by adding a new turbo, platinum plugs, bosch 040 and vlt fuel reg..compared to std plugs....n/a pump and reg
Guest
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
