Item: 89 model Nissan skyline r32
Item Condition: Interior is in good condition with a boost gauge and turbo timer and shift light mounted with GTR seats etc. Exterior has seen better days as there is a few dents now. But these can be fixed before changing hands if need be or before hand prior to inspection. Want to sell as is though.
The car has a series 1 rb25det in it with some mods including a full 3inch exhaust from turbo back. High flowed cat. FMIC. High flowed turbo done by sliding performance rated to 550hp. Boost controller running 12psi with a bosch 040 in tank pump brand new fitted by Dave at High Tech. Also has a Microtech lt10s with hand controller.
Car on a very safe tune the car made 208rwkw at 8psi and 228rwkw at 12psi.
Rego(if applicable): Can come with new rego with no problems its has just run out
Location: Darwin but will help with shipping. For a car from here to say Melbourne is around the 900-1100 mark
Website: This one and Boost cruising
Reason for Selling: Need money.......... Fast so no swaps please
Price: 8000 as is. Or 12,000 fully fixed and resprayed Negotiable
Payment Conditions: Cash
Extra Info: Car also has full coilover suspension (JURAN) and slotted and cross drilled brake rotors. 17 inch gram lights, Sway bars, Hicas lock bar, Drift pinaples and rear camber arms all adjustable, reshimmed LSD that works a treat on the track. The vehicle is well setup and has been pretty successfull in the darwin drift circuit with two 4th places in the comps. plenty more bits just cant think of them all right now Brand new extreme extra heavy duty clutch and rb26 flywheel. Around 600klm old
Contact Details: PM me on here or phone 0404963918
Edited by super_s13
I know that feeling. I dont have cash to ship a new car up so i cant except swaps at the moment. But 8k is dam cheap for a r32 with a 230rwkw rb25det in it.
Just needs injectors in it and will get around the 250 mark with few more psi. Needs to go soon though.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
