Turbo Upgrade Question (i Already Searched)
hey guys, i have spent days searching here and google and please point me in the right direction if i have overlooked sumthing.... however
i am planning on building a rb25/30 twincam engine.... im looking at doing it on a strict budget and am aiming for about the 200-300rwkw mark (depending on combo). i have got a power fc with z32 afm... to start with.....
so my question is... what is a good responsive turbo option for this setup??... i would like to reduce lagg, improve responsiveness and overall power/reliability...
i have been told to look for a vl turbo and high flow it and make sure i get a .63 exhaust housing or sumthing......can anyone shed any light on this?>?
p.s sorry i should add... iv seen all the links with the recommmended t03/t04 turbo upgrades and t04e blah blah.... but i couldnt make much sense of what turbo has what type of shaft, and wot turbo was good for what, and which turbo was newer etc etc....
thanks for ur help
Edited by TRB-001
well 200rwkw to 300rwkw is a very broad range and covers a lot of turbos.
If you check the dyno sticky thread, user "AL" has a GT3076 and near on 300rwkw...
His results are very well documented.
I wouldnt bother with some hi-flow. get a decent turbo
If you are looking at 200-300rwkw, a stock-internal RB25 should definitely be up to the task, especially if you are on a 'strict budget'.
There are plenty of people on this board with MUCH more knowledge than me, but AFAIK, building a reliable 25/30 is not a cheap exercise, and if you are only going to put a high-flow on it anyway, you may as well not bother.
There are hundreds of threads on here about making 200-300rwkw out of an RB25 but with; PowerFC, 550cc's, z32 (or perhaps a custom AFM), fuel pump(s), and a GT30 or 35 based turbocharger, you should make near what you want.
Do some more searches and you will find.
If I have misled this man, please correct me
Edited by Yeedogga
thanks axs s for the heads up.... ill keep an eye on that one!
really i think my problem is there is so many different turbos out there these days i dont know the differences and wots good and wots not....
any other ideas..... or info would be great
believe it or not this can all be searched for pretty easily but here goes.
there really are only two choices in the Garrett range that meet your needs.
GT3071 and GT3076 both should come with the identical turbine (60mm) the difference is the compressor.
in simple terms the 71mm compressor is a 450hp compressor (depending on trim this number can vary)
in simple terms the 76mm compressor is a 500hp compressor (depending on trim this number can vary)
so this should net you between 250rwkw and 300rwkw on whatever engine you slap it onto ie RB25 (the cheapest and most obvious choice or as you state you want a 25/30 hybrid.
there are other options like a quality hi-flow which usually come with the 71mm compressor anyway in a nissan housing some are ball bearing ($1900ish) or bush bearing ($900ish)
alternatively you can look at other brands that are more expensive rebadged garrett units like HKS branded turbos (that are all sexy gear with HKS's own turbine covers that work really well).
alternatively other name brand japanese turbos like Trust apexi etc.
OR if you are feeling like doing something less common in australia find a Holset like one of the current threads is doing.
Edited by wolverine
mate if your on a cheapo budget i advise you go to ebay and fight the right combination of a/r and slap it on, very cheap, and personally i havent heard of any them going wrong. yes you get what you pay for, but at >$500 for a big mofo turbo you can over 10times before it cost you as much as one t04z. its the blokes who pay big money on thier cars and get no real power that whine about ebay turbos
3076r plus rb25 will see at least 250kw and the turbo should only cost you about $2000.
keep away from ebay turbos. i know people who have used them and got less than 200km of highway driving out of them. no point spending the money to only have to keep spending money.
For a RB30 Twin cam its recommend that you go for a .84 reared turbo. We can make you one that is capable of 320rwkws that doesn't blow your budget. Drop us a PM if interested.
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
