R33 with 3582r (i will check housing size 2moro for you) 18psi but with 264 cams.
Fuel reg on a r33 is good for high 300rwkw so your reg is not the issue.
Edited by URAS
Yeah, thanks for that. Doesnt matter what gear youre running , it all comes down to a proper tune doesn't it? Funny thing is this guy has one of the best reputations in Melbourne and the results to prove it, but i highly doubt that he tuned my car. Anyway i will post both dynos once i get it retuned elsewhere.
It's put in 4th gear so the tuner is able to tune it.
For example, you would not be able to tune a car in 1st gear because power just comes on way too quick.
Yes it does matter what gear you're in, 1st and 2nd gear will have much different power graphs compared to 4th gear.
Take it to another tuner to get a second opinion. Maybe something was wrong with the car (i.e. detonation) so the tuner had to pull timing out of it, hence the low power?
Maybe there's carbon build up in your engine causing pinging, or a hot spot on the piston.
Take it to another tuner, if he tells you he couldn't pull anything more than 250rwkw without it pinging of its tits, then somethings wrong with your car.
The fun and games begin.
Yeah thats exactly what im going to do. He said everything was fine, that there werent any issues and was actually quite happy. Its not that i want more power, cause its fine the way it is. Its just that i believe that with this set up (barring any issues such as the ones you mentioned) the car should have pulled more than it did. As i said i really got the impression it was done in rush to get the car out of there, and im sure it wasnt tuned by Mark himself.. I'll be booking it in this week sometime elsewhere..just for peace of mind!
got same setup, apart from I got the 0.82 A/R. I have a VERY conservative tune (f#$k all timing, and running rich, knock doesnt go over 15) and I made 312 rwkw at 17 PSI.
I suggest you go see another tuner.
the 0.82 makes 300 easy the 0.63 does not.
Edited by URAS
    • Upgrade your Skyline or Nissan JDM Vehicle with this fully restored set of OEM Nissan Skyline R32 wheels, perfect for collectors and enthusiasts. • Authentic JDM Factory Wheels • Includes genuine Nissan center caps • Size: 16x6.5J, Offset +40 (OEM spec) • Gunmetal Grey for a clean, factory fresh finish • Suitable for 1989–1994 Nissan Skyline R32 and other models with matching specs • Tyres: Mixed Bridgestone and Kenda tyres included looks to be at least 90% Thread • All Centre Caps Display The Year 1989  They maintain the iconic OEM look that R32 owners love. Whether you’re restoring your Skyline to factory spec or upgrading from aftermarket rims, these are a rare find in this condition. Price:$1400 located Western of Melbourne I can also arrange a courier Australia wide at the buyer’s expense if needed. Just send me a message
    • I agree, most likely a sensor issue. You didn't mention how it was running but above about 20:1 it won't run anyway
    • my guess is 2wd and 4wd are not interchangeable, but in any case you can just buy the bush (regular or adjustable) instead of a whole new arm
    • Shipping from Japan, get them now before the end of year delays! 👍 Only 2 left: 1973 Toyota Celica LB 2000GT --> ¥6,500 JPY  https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt Only 1 left: 1970 KPGC10 Nissan Skyline 2000GT-R --> ¥9,750 JPY https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r Only 1 left: 1968 Mazda Cosmo Sport --> ¥7,500 JPY https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport
