Hello boys girls and everything in between, my name is Stefan, 25 summers of age, and I live in Holland.
The last few weeks, I've been the owner of an R33 from 1993, so that's a Spec1 GTS25t.
I'm a student and I work 30-35 hours a week(-end) to pay for my addiction to boost.
Previous cars have been a couple of Civics, two Starlets, an '89 CRX, and the most interesting ride I owned; a 95 Civic coupé, fitted with a B16A2 (1.6 twin cam VTEC) engine with another set of cams and a T3/T04E turbo, and the whole circus arround it... pushing about 300-325hp at the crank.
With wich I do not dare to bore you, so here's my Skyline, already been modding it, mainly removing trash, cleaning up the engine bay, etc.
VEHICLE DETAILS:
Nissan Skyline GTS25t (ECR33)
Build 1993, (import JPN->UK = 2006, import UK->NL = 16-05-2009)
Dark gray metallic
ENGINE:
- RB25DET, stock
- T28 turbo, stock
- Apex'i cone air filter
- stock after-turbo elbow
- Bullet Exhaust 3" stainless steel downpipe
- stock catalyst
- 3" RS*R catback (with Invidia end tip...?)
SUSPENSION:
- Kakimoto Racing 2pc. wheels (17x8.0JJ +34 (FR), 17x9.0 +37 (RR), made by SSR)
- Falken GRß FK451 (FR = 235/45/17, RR = 255/45/17)
- stock lsd
- HICAS
EXTERIOR:
- Tommy Kaira bodykit (front bumper and (custom) mesh grille, sideskirts, rear spoiler, rear bumper flaps)
INTERIOR:
- Simoni Racing steering wheel (temporary)
- FET turbo timer
- Räzo leather shift knob
- HICAS-hub
- Sparco black hub spacer
SOUND SYSTEM:
- Eclipse doule-DIN head unit with in-dash 6CD-changer (display has died)
- stock speakers front and rear
VIDEOS:
http://www.youtube.com/watch?v=xFY1utN7-vE
http://www.youtube.com/watch?v=iPxb_QtTVqg
PICS:
Plans include (in random order) a brake upgrade, FMIC conversion and sideflow manifold, GT-series turbo, top mount manifold, replacing the rear spoiler with a Spec2 or GTR wing, lowering it, new wheels, seats, a roll bar and other chassis reinforcements etc etc.
It's a daily driver, so no dori dori :D
https://www.sau.com.au/forums/topic/275242-a-big-hello-from-holland/
im going to holland in a month.... 6th-10th of july.... staying in amsterdam...
your car looks very clean and tidy, if i see your car i'll give you a wave
whats the fuel quality like over there?
half my family is from over that way also, originally from Emmen i think?
Could be better, but could be a lot worse as well.
Traditionaly we have Euro 95 and Super 98, then some premiums, wich often are 95 RON or 97 RON, never lower than 95 RON.
I never go to a Shell station (they only sell 95 RON), I prefer Esso.
And your family is from Emmen? :down:
No kidding... I live right next door haha, it's a 30-45 minute drive to the north west from Emmen to my place.
Don't expect to find me in Amsterdam, I avoid going to that city full of nutcases and junkies... everybody is full of hot air, nobody in Holland likes people from Amsterdam, except for people from Amsterdam.
At least, that's what we think here, up north :P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
