Ok I'm trying to organise a cruise for either Friday or Saturday. Not going to be a slow drive, so those who are interested in a really good drive, please leave a message.
Also please tell me a prefered time and day. Right now im thinking 11pm meet on Saturday.
ROUTE: Higher Speed runs, Corners, DRAGS.......................
ANZAC HYW, EAGLE ON THE HILL, MOUNT LOFTY, FREEWAY, Etc etc.................
https://www.sau.com.au/forums/topic/27526-cruise-anyone/
gee N/A with a post like that do you really expect a night of cruising without incident? and posting your planned route sounds like a real good idea buddy. Theres a lot of ppl giving car enthusiasts a bad name up here in NSW at the moment, its ppl like you that are really pissing off the public/police etc etc giving us all a bad name. Are you 18, on P's and drive a Silvia Q?
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-577040
Yes, nothing wrong with that is it?
Also, i'm wanting a good cruise where you have a chance to give it a little. For example, I have never driven up Eagle on the hill slow.... this doesnt mean i will be driving like a maniac every where...
It is no different than driving fast through black wood or dragging a 200sx on ANZAC. But this way, you get to more people to join in the fun. :)
SO DONT MISUNDERTAND what kind of cruise i mean
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-577141
Originally posted by BOOSTD
You got it all wrong, N/A drives a turbo gemini stationwagon. It's fullysic
Oh comeone man, now the coppers are gonna know who i am.
So you up for another drive this week? If your mate with the gtr 33 decides to come out, let me know so i know wheter to drive the gemini or silvia Q :D
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-577865
Baahhh, you guys have got no chance if I bring out the Sigma! 2.6 litres of raw ground pounding ggggrunt, well, at least 30 or so rwkw up to 3k & then she's as breathless as an 80yr smoker with a collapsed lung :(
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-578516
Your sigma might get me at the end simply because mine is a station wagon and heavier. STEALT MAN!!!
My gemini makes 0ver 47kws @ all four wheels. But I cant get it tuned with the Power FC because I dont trust anyone in SA. Just incase the motor blows up. Any recommendations?
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-578554
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
