I currently have a set of Tein Wagon coilovers in my car and have run out of adjustment to lower it any further on the front. The Tein spec's say 46mm max for the front and rears are 71mm for the rears. 4KG front and rear.
The car needs to go a further 30mm in the front to get it looking right. The rear needs another 20-25mm which should be possible with the Teins as they have not run out of thread yet.
The choice is to
1. Find another full set of coilovers
2. Change the fronts to a different style or brand maybe something from a GTR
3. Get new springs made for the fronts if possible. The shock might run out of travel.
It is a bit hard to provide a accurate front measurement from the centre of wheel to top of the arch of the front guard, as I have a R34 front so it maybe different to the factory stagea guards. It is currently approx 355mm
So what shock combo's are you running and what is the ride height measurements and much further can they go?
https://www.sau.com.au/forums/topic/275261-how-low-is-your-stagea/
  • Replies 48
Do the teins have helper springs? If so take them out and there's another 30mm. Bit of a ghetto drifter type mod but works till you can save for some more.
No helper springs
How low can the bilsteins go?
I have v35 king springs in the front of my m35 at the moment. I scrape all speed humps and bottom out on the road while driving (I can just get my boot under the front). Very unpleasant ride as the standard shocks are either too soft or stuffed.
I'm about to import a set of HKS LS+ coilovers so I can wind the car back up, that should sort out the ride problems.
Don't know how it passed roadworthy.
Mine has Nismo S-Tune Suspension with the Aero Kit, the front of the aero kit has scrapped many times, especially on steep or long driveways.
Also ripped the centre cover off @ Windsor, was a nice lump of asphalt in the middle of the road, should have heard the nice bang when I hit it :D I had it checked out and Unique Auto Sport said there was just a bit of scratching/missing paint underneath.
Hornsby Nissan just fitted the other day the new improved centre cover with metal guard on the front of it, should last longer :D
Needs to be lower than that one
I need measurements to back how low your car is guy's. If it sometimes scraps or hits something, that's all good and well.
I want it be lower, so need to make sure I buy the right coilovers that fit the job!
Only C34's need apply.
ok cool just checking
but i think the reason why your current coilovers dont let you lower it anymore is because going further would have an adverse effect on the handling of the car.
can you have your current ones threaded further down and put a longer spring in?
Tein suggest only 25mm drop with these shocks
It would problably be not worth modifing them, cost too much, plus they are almost new. Less than 5000k's
Plus the shocks will not like the lower/reduced travel.
On my S1 with Bilsteins and Tein springs it is lowered about 35mm. If the lowest setting on the Bilsteins is not low enough for you you can cut more grooves until the suspension becomes useless if thats what you want.
So you are on the lowest setting on the bilsteins? But what height/length are the teins. Are they lowered or standard height?
Bit hard to compare. The lowest setting on the bilsteins might be low enough for me, but until you quote the ride height measurement, it is a bit hard to compare.
Not really tring to make the car useless, just trying to fill out the guards.
In sydneykid's group buy, he was setting the car the at 350mm. I believe mine sits higher than that, but I have ran out of adjustment to lower it further, hence the need for asked info. What shocks and what measurement are people using?
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
