hahaha, just like hire cars are bestowed with special abilities, like eternal high revving motors........
just noticed your avatar! where did you get those photo's? do you have more? of mine maybe? that you promised? can you send me a link to them?
hint hint hint......buddy pal mate!!!!! :P
  • Replies 48
Looks pretty standard height wise.
How high do you want it?
If you are having an issue with that ride height, I would suggest that you forget all about a 3" turbo back exhaust!
I think the ride is/close to standard. it's the front bar and exhaust that give me dramas on steap inclines. it might also be that I'm not used to the length of it yet. I still haven't walked the whole way round it yet. I'm going to set a weekend aside for that. :P
Got mine sitting on Tanabe Sustec Pro coilies. Its currently been lowered about an inch over stock but its still not quite low enough for my tastes. Good thing theres at least another 1.5" available all round :P
Only problem then is the stupid speedbumps at the end of the road, right in the line of the sump and downpipe - i get scrapping now as it is.
Oh well
fronts real low, as low as possible without strut bottoms sitting on the main arm (cant remember the name), rears arnt super low its actually at max height setting with a full tank of fuel to lower it
i think its around the 320mm mark from memory (im running bilsteins too with heaps of extra circlip grooves)
thanks guys the skirts are not that nice (though without skirts the car looks even worse haha), they dont suit the way the door tucks under, im gonna modify them a fair bit i think, though they do look alot better in person and i got a few decent photos of the car from the HPI shoot but i cant post them online until its in the magazine. Ill throw the lmgt2s on and get it to somewhere decent and take a few pics soon when the new motor gets installed this weekend coming i hope :rofl: I got the front and rear bars for the nismo kit also sitting here im unsure if i like them or not, they will get test fitted soon as well and see how i like . Oh and the 33 gtr wheels need a 20mm spacer on the fronts they sit too far in the gaurds it looks abit shitty, the rears are spot on though.
Edited by unique1
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
