guys im planning on getting these wheels of a mate of mine in brisbane this is all that was given to me. he told me to check if it is possible before the go ahead. 5-120, 20x8.5
help please?
Sorry mate. Is that 5x120?
If yes. The answer is No. V35 need 5x114.3 to fit.
Frank
weaksauce
:D
Hate to see what you'd type on the oem 18's then lol!
I actually want to change my wheels too but really poor atm.. It'd only be for aesthetics though. I think the oem 18x8 on v35's are quite light (around 10kg iirc). However, i'm not too keen on running say a 9.5 on the rear etc then having to fit a big tire and giving the car too much grip..I like how it's balanced now - perfect (for me).
OEM rims have the benefit of being free with the car. There's no shame in rocking out poor offset and widths when you didn't pay for it.
Most 20x8.5s I've seen have had pretty weak offsets too, since they're designed for ricewagons (like sik WRXs) that can't run nice offsets. If I see another guy on 350Z-Tech wanting to know if they should run 20x8.5 +40 I will headbutt something.
Why not upgrade the front and rear together, and keep the ratio the same? Or just run a wider rim, and strech an OEM sized tyre onto it?
If you upgrade the tyre widths all round by the same number, the ratio's of width front/rear remains so similar there's not much in it. You could just change the pressures to fine tune the balance afterwards.
:D
I loose traction quite easily still with a 295 on the rear....... granted that only 2/3 of it is only making contact with the road............
To scathing, since you sound like you know your stuff in terms of the wheels size and offsets.
what do you recommend on the 19" and 20" for a perfect fit, looks and feel on the road?
can you also incorporate having the car an inch or inch and half lower.
thanks mate.
Mark (Blistc) whats the full spec on your wheels at the moment? i can probably relate to you more since both of our car are dropped!
thanks mate.
current setup is 19 x 9.5 +8 Front 265/30/19 tyres | 19 x 10.5 +18 Rear 295/30/19 Tyres -2.5 Degrees Camber All 4 Corners. Top of Rim / Tyre sit flush with guards, poke out mid - bottom.
Car lowered on TEIN Comfort Sport Coilovers. Car is only about 50mm off the ground right now as it sits............
Nagisa Auto Rear Camber, Rear Toe, Front Camber Arms as well in order to correct the camber to get it to sit the right way i want it
If the camber hardware is stock then the accepted "best fitment" is 9.5" +22 front and 10.5 +22 rear, even if you lower the car. There's no front camber adjustment at all, and limited rear camber adjustment, on our cars. You can get away with a few mm each way but since most people opt for Volks they're the most common offsets for those widths.
With the suspension geometry, if you lower the car the wheel naturally cambers in (as if it was being compressed that much from the stock height due to load). As long as you don't hit the end of the suspension travel and rub the inner guard, the height is irrelevant to clearance.
I've got 18" wheels in those widths and offsets on my Z33. I've run a 265/35 R18 and 285/35 R18 with as little rear camber as the suspension allows. My guards aren't rolled, and that setup doesn't rub. If you go 19" with the same tyre circumference, it should be the same.
Here's what mine looked like:
Theoretically you can go wider. I've seen a US-based 350Z running 18x10.5 +15 all round while lowered, but the front looked a bit retarded (the wheels stick out a lot). The guards were rolled and he had aftermarket camber bits. I think he was running 3-4 degrees of neg.
Mark would be the best to ask if you want to push the limits of offset with modified guards.
As for 19" vs 20", of course dropping the tyre profile and increasing the unsprung weight is going to have negative effects on handling and performance.
As for looks, that's in the eye of the beholder. I personally like a reasonable amount of sidewall on a tyre, but the V35 looks more awesome with big diameter wheels than my Z33, so for me I'd probably run 19".
If I were to get a V35, I'd probably run a 19x9.5 front and a 20x10.5-11.0" rear (I want to go as wide as possible for aesthetics). The offsets would be in the mid teens and I'd run a touch of neg camber, but not more than around 2-2.5 degrees.
Edited by scathing
Oh yeh i forgot to mention
i had to roll my rear guards, just roll the lip underneath.
When the car is fully loaded with people, (2 people in the back) the tyre clears the guard by around 2mm. You cant fit anything between the tyre and the guard, not even a coin. Suprisingly, i couldnt hear the rear scrubbing at all and i was driving on the shitty part of hume highway at bass hill area too........ so i am very happy with my setup.
please note i still have stock guards, they are just lipped underneath on the rear. The front there is no need and it more than enough clearance and no scrubbing at all
also i remember people asking me at the meetup "where did i get my 20's" to be surprised they were only 19" - its all about the stance.
Edited by BLISTC
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
    • Most of the R33 GTST S1 are all like "airbag? What airbag?!"
