HI all, I don't get on the forums much these days, but I thought I'd share am easy way to fix gutter rash/minor curb damage on your rims.
Note: This will generally only work on silver/polished rims with small lip on edge of the main lip (if ya get what I mean!). But may be able to be used on other wheel for various functions such as sanding before paint/powder coating etc.
A while ago I bought some second hand Brabus rims for my ride. They were in good general condition, with the usual minor nicks here and ther. One of the front wheels had gutter rash all around the outer lip. It wasn't too deep, but it was damn ugly. Now, I am a cheap bastard being half asian, but I also love giving things a crack. I had heard the local rim repairer couldn't do 19" rims, but never bothered to investigate, so I decided I'd give fixing these a go myself.
First I went out and bought two cheapish files, a straright cut bastard, and a plain flat bastard. I was having new tyres put on, so had the current Hankooks removed as I was gonna sell them off anyway. While the tyre was off I got down to work and did this.
First photo is of original curbage when I bought them. And I have used the same method twice, second time was for my bros small curb incident. (He did send me a nice set of Bahco files though!)
Original curbage around lips lip! All the way around
Tyre is removed from wheel, car is jack up (axle stands used of course!) at the back and rim put on. Essentially this is the poor mans lathe. So to clairfy. The cars rear end is up, and on axle stands. I can't remember if I removed the othe side wheel, but I think I did. I tryed the car in 1st gear with the engine at warm idle. It was a bit too slow.
I found second gear with the car at idle to be a great speed for the wheel to spin at. And basically I sit there with the files (straight cut bastard and a standard flat bastard) and work the curb rash away. Here you can see metal I have worked from the rim. After the rash was removed, I did a rough sand, then a finer sand. I can't remember the grits, but I'd imagine 180-200 and 300-400.
First time I did it, I was having new tyres put on anyway, and second time round I had the tyres rotated (staggered set, directional tyres,can't rotate whole wheel). So all up it cost me only time and about $30 for the two files.
After the file I sanded it to a smoother finish, then applied a little metal polish. No need to paint as it looks fine how it is!
Pretty easy and cheap for an arvos work. As you can see, this won't work on all rims, but may be adapted to do some of the work yourself if you are having your wheels painted/powder coated etc.
Please also note that safety must be considered paramount at all times. Axle stands must be used at all times and a second person should be there in case of emergency. Keep hands away form the wheel spokes. You get a hand caught in there and your in a whole world of hurt. I take no responsibility if you are injured trying this process out.
Good luck, I hope this helps some of you!
Richie
https://www.sau.com.au/forums/topic/275277-cheap-curb-rash-fix/
yeah what they said .. if you're broke and can't afford a proper fix worth a try I guess. But seeing as how most pros charge $60-100 per wheel depending on damage, it's hardly worth the effort imho.
I got quoted $200 by Magman in Sydney to fix 2 wheels .. both have pretty bad gutter rash all around the outer lip and one of the wheels has a rather large chunk of metal (about 3-4cm) sticking out and needs to be welded back on
so your sitting there with a file rubbing against the wheel while your car is jacked up and running on second gear. your broke but are you retarted as well? i would never trust jack/axle stands with the car running in gear at the same time. fromt he viberations of the cars running gear if the car falls you will get hurt pretty bad and your car will get damaged also.
i eman the results you got are great
but your method is very risky and id rather drive my car aroud with gutter rash and save up rather then doing it this way
  • 6 months later...
I dont know what some of you are complaining about. if you set it up properly it is perfectly safe.
i just did this, works great. after i finished with the file, i used some 120 sand paper and then finished off with 400.
i saved myself $150 a wheel and i actually enjoyed doing it.
i would be more worried about people hurting themselves with the tyre levers trying to get the tyre off the rim than actually hurting themselves filing the rim (i've changed a few sets of tyres on rims manually before and have had 1 or 2 close calls with tyre levers going flying up into the air). if you were worried about running the car to smooth out the rim, you could always just take the rim off and sit it on the ground and file it. wouldn't come out as nice though.
  • 3 weeks later...
you could always just hold the file on the outter side of the wheel so if you do slip your hand simple goes into the wheel arch, and if it does happen to hit the wheel it will only be the outside of the rim.
but to the people who are actually scared of this, there are a hell of a lot of more dangerous tools out there. basically all he is doing is using the car as a lathe. nothing scary there. i'd be more scared of a simply angle grinder than doing this (and i'm not scared of an angle grinder, although i am still cautious with them).
  • 3 months later...
Dont do this in an enclosed garage either... exhaust poisoning anyone???
But seriously, there are some people out there who should not be near tools, if they can handle them selves, and are farily good with this kind of thing... BIG dollar savings to be had.
I have done this in the past, just as long as you use common sense you should be ok. I also had a 2m kilswitch line rigged up too, so if you need to... hit the big red button. everything will stop rotating soon enough (especially in gear)
2nd person nearby is a VERY good idea aswell.
Not too shabby of a method. Provided you have a nice flat surface. People worrying about losing their hands. I doubt very much you need to apply such pressure onto the bastard to start shaving the wheel. Light pressure and keep your hands away from the gears. I would have tried this except my rims aren't silver, they're painted and I cbf matching the paint.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
