i got 15" GTS type-S barrels/rims over my GTS-t Type-M calipers, but the disk fouled at the front, rear was fine.
depends what silvia ur talking about, AFAIK S15 15" stockies are 5 stud, so they might fit, my worry is they will foul on the disks.
S15s did not come with 15inch wheels standard... I think he's talking about S13. maybe NA S13 or something. and yes S15s are 5 stud, but he's surely not talking about putting GTST brakes on an S15 they are basically the same thing. only the S15 ones would be much newer...
Toby has a rally car (make and model unspecified) which is fitted with 15" rims that happen to also fit a Silvia. He wants to know what size rims came standard on a R32 GTS4 so he can determine if the GTS4 brakes will fit inside the 15" rim.
The number of studs for the "Silvia" rim is totally irrelevant to the question. And which Silvia / 200SX had 15" rims or 4/5 studs is also irrelevant.
In answer to the question - as previously stated, R32 GTS4 comes with 16" rims standard. That does not necessarily mean that the brakes will not fit inside a 15" rim on his rally car. That will be governed by the size of rotor on the rally car, and the relative position of the caliper mounting lugs on the strut. It will be pretty much "suck it and see".
Hi mate,
You understand my question EXACTLY!!! I have an S13 SR20T rally car which I would like to fit the 4 spots to the front. I know they bolt on and I will be getting new blank rotors and redrilling them myself to 4 stud.
Looks like I will have to "borrow" some old rotors and calipers off a GTS4 so I can trial fit them. I am a little worried seeing as the donor car (GTS4) had 16's as standard. I do have a couple of different sets of 15 inch wheels, so I might be lucky and get the brakes to clear.
Thanks for all the responses guys!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
