I got stickered :D
Cops reckon my exhaust is less than 100mm from the ground so *slap*!
i needa take my screamer and de-cat out, adjust my ride height and i needa ask
Can i borrow someones standard rims with decent tread for pits? Will be going over next week and i hope i don't get royally raped :)
Cheers :D
https://www.sau.com.au/forums/topic/275292-stickered/
  • Replies 70
ah dont stress yourself about it. I got done for the same thing recently. I got an awesome inspector at Welshpool and he passed me with heaps of defects still on there. At the end of the day you should prepare for the worst and hope you get a nice inspector.
Have you checked that the exhaust hieght is ok. The cops gave me a flick knife to test my exhaust height. It was probably 80mm from the ground
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4664124
^^WHS
100mm from the lowest point with a fully loaded car, so if your at 110mm you might still be considered a little too low by the cops.
Also something like 400-500mm from the lowest point of the headlights or something, I never pay much attention to that one.
Basically, if its lowered enough to look good its too low.
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4664665
I'm pretty sure it does, had a few mates fail because their kits scraped.
I've also heard that even a wire hanging down counts, because if it's for a fuel pump or something, it rips going over a speed bump, the car will suddenly be inmovable causing headaches for everyone. That's what I've heard anyway.
Point is, kits are included in the too low rules.
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665426
Yer i work at DPI, but that doesnt mean i will get a nice inspector.
Rhys - yeah i have coilovers and will just wind 'em up and take my screamer and de-cat pipe out.....might come cruising tomorrow night not sure yet
ADR rules state the you are not allowed to have different rim width front & rear unless your car came with different rim widths from factory.
Anyways, cheers for teh replies, i'll get back to you tomoro, im sleepy now :D
hehe ciao
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665584
Stick with the 100mm from the lowest point of the car rule nic, otherwise fools with 20" rims on their fully sick honda accord Si's that are FAR too low will be more legal than an dumped XA falcon (for instance) with standard 12-slotters.
mates escort pano's lowering block u-bolts were 120mm from the ground, and had like 14x8 custom jelly beans. coppers sent him on his merry way. cop measured a brick that he found to around 100mm and stuck it underneath...
gotta love country cops. normally don't spell it with an 'o', but 'flamin mongrelry' cops doesn't make sense.
Edited by Dorigecko
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665609
Yeh, when it comes to ride height, 100mm is the lowest point of the car. That's for everything (kits, cats....mmm kit-kats).
My mate just took his R33 over the pits and he got failed on his rims being too big (R33 gts-t with 19x8.5s all round), and having a spoiler on the boot but not having a brake light in there (as u need a brake light at eye level so they). However, i have taken the spoiler off my car, as you know Rhys.
I might come just to the meet point tonight for the cruise....im sick as a dog atm so i'll see
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665975
Unlucky man, I almost got yellowed the other day cause the cops were saying my tyres were to big.....lucky for me it started to rain and they went 'f**k it' :down:
Sorry to highjack, but.....
Are 235's on the front and 255's on the back to large for a R32 GTS-T??
I mean, it is right on the guard, and may even stick a mil over....
Edited by Douse
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4666065
Yeah Id say it is.
What are the widths of your wheels?
Your not supposed to go with anything much wider than the widest that came with that car.
So you can argue that the GTR came out with 8" wheels and try get away with say 8.5"?
Any wider and it's too wide unless you get permits/engineers.
Sad but true.
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4666116
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
