I have recaros in my stagea which were R33 GTR skyline. I know because the recaro boxes actually had 33gtr skyline stamped on.
Im short and whilst they are lower I have no problem in seeing over the bonnett. might be different with stock GTR seat but I would have thought they will be fine
I'm soon to have a set in my car, Darrin. They're from an R32 and are being re-upholstered at the moment.
Either way, I have the factory seats set to the lowest setting now, and I'm around 5'10" tall.
I have R33GTR seats in mine and I'm 5'10
You do sit lower, but its a comfortable low, and no problems seeing over the dash at all.
Thanks for the reply's. I use to have Garage Impul seats seats in mine with skyline rails and they were lower approx 30-40mm than stock seats. I am 5' 10" as well
I have a spare set of stagea Bride rails, so tosing up between using them with new bride seats, either Euro II or Digo graduation cloth and retrimming the rears and doors to suit, or I also have a spare series 2 manual rear seat and door trims which are almost identical to R33 GTR cloth. Using GTR seats will be alot cheaper option, but the Brides will look good :D
Was also looking at buying s/hand recaro's and retrimming them, but the trimmer wants aprrox $1000 just for the fronts. Might as well buy new ones.
Nick, what is it costing to get the gtr seats done? What sort of cloth?
That's pretty much what I did with mine.
Here's a pic so you can see how the seats and trim go nicely together.
I have 33GTR seats in the 32, if i keep the stagea they might go into it and buckets in the 32, or more gtr seats, they are sooooooooo comfy. stagea ones i dont find supportive enough in the lower back, so the harder GTR seats are great. i am 6'2", and my shoulders are getting on the high side for the GTR seats though.
The rough quote so far is $1400 for all cloth, or $2400 for all leather, so I'm guessing that the final cost will be somewhere in the middle, as I'm going half-and-half. That, though, is for the whole interior: front and rear seats plus door trims. I picked the colours and materials the other night, so it's not too far off, hopefully.
I've got the R32 GT-R rear seats still, so I really should advertise that, and after the rest is sorted, I'll have a pair of Stagea front seats to get rid of too.
I want to know HOW much lower do you sit with GTR seats
Hard to see over the bonnet?
Hi Darrin,i don`t have GTR seat`s but 32GTST seat`s & you sit some 90 mm lower & it`s a lot different looking over Bonnet but it`s so much more comfortable as you now feel apart of the car instead of sitting on the Couch,post-36964-1245453736_thumb.jpgpost-36964-1245453822_thumb.jpg
cheer`s chuckie.
What rails are you blokes using?
Pretty intererested in swapping my seats for ones that acutally hold you in. Are you able to use your existing rails to suit GTR seats?
Edit: After using the search function, I found the answer I was looking for :rofl:
Edited by d1_drifter
Hmmm, I already have the standard Stagea seats set at the lowest point at the back and a little bit higher at the front to provide some under-thigh support, so I wonder what the new seats will be like.
I (finally) got my recaros fitted the other day: it took custom sandwich plates between the seats and the Bride rails: perfect seating height: maybe 10cm lower than standard: very happy: haven't even bothered with a quote on full retrim yet: I am waiting to get my manual console first...
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
