ok here's my tale
Today on the dyno my car was given a run up with new turbo and new injectors with the old tune.
- 114hp @ wheels
- 10.1 AF.. or lower... 10 was the lowest on the scale
it was a no brainer that it was over fueled.
A quick adjustment of maps:
- 209hp@wheels@6000rpm
Nothing special, car had that in its previous stock form. However the turbo wasnt reaching boost till 4500 rpm, then slowly built up boost to 14psi.
- Finger was pointed at the EMS boost control solenoid being to slow to bring on boost.
The solenoid was sorted and boost was coming on at 3200rpm feeling stronger. BUT.. heres the but...
- Soon as the car reaches 5000rpm it seems like there is an ignition cut and stops the power.
We are scratching our heads as to why, New plugs were put in and gapped to 0.8.
- Rev cut is 7900 hard, 7500 soft
- boost Kpa cut is set at well over 1bar ... car hit 17.1psi at one stage earlier.
- boost when ignition breakdown occured was 12psi
Anyone got any ideas?
*Have been told*
- at higher boost pressure the spark plug electrodes can bounce resulting in ignition breakdown... (the tips close then open.. boucnce)
https://www.sau.com.au/forums/topic/27530-ignition-breakdown-techie-question/
Steve,
I am using BCPR6ES gapped to .8 minimum.
apparently the tips of these can 'bounce' under higher boost pressures and cause an ignition breakdown as i am expereincing. Have you got any input on that at all ?
I have been recommened by the shop to use Iridium ($20 per plug)
Up until today i have laughed at everyone who rushed out to use iridiums, as i saw normal plugs working fine, but to have this sudden break down has made me wonder....
Do not use iridium tipped plugs for forced induction applications. Our experience has shown them to be severely lacking when it comes to boosted engines. The tips usually break off then the plug is cactus causing all sorts of misfires.
i think they are gonna try some expensive ass plugs tomorrow :S
doubt its a coil pack, never had a problem before, and as stated, was running fine minutes before this current break down happened.
Dyno Day 2: No result
ok they put in iridiums, didnt fix the problem.
The car did 1 ramp and was nice and clean, BUT STILL ONLY 206hp on 11psi!!!! WTF
car went for another ramp... and the breakdown appeared again.
The place is pissed off and so am i. Platnum plugs are being tried tomorrow.
well if its not fuel, its most probably ignition.
I dont want to tell pork pies, but I have heard off this forum that the EMS wastespark setup was attributed to frying coilpacks. I have only heard of it the once.
As GTSt suggests, probably a good idea to be looking there next. If you know someone with a skyline see if you can borrow there coilpacks for a couple of dyno pulls - will soon enough tell you if that is where your problem is.
last dyno tune we swapped all coil packs due to a missfire
all coil packs were good... the miss fire was an error in their tune!
i am wondering about the actual ignition module now.
Also...
the 1:1 gear in my car is 3rd. Should the dyno run be made in 3rd gear, or is it 4th gear no matter what ?
ok for those interested:
The ignition break down was actually the car getting too much fuel! yet the AF were 12.1:1
Dyno guy took the car for laps around the block takeing fuel OUT!, said the car seemed heaps better and was running alot better.
Comes back to the dyno, does 1 ramp, 11.1:1 AF !!... taking fuel out made the car run richer! We are both stumped as to why this happened.
very weird indeed. Should have the car back end of today, tomorrow morning at the latest
yeah all sensors there.
My guessing is that somehow the fuel limits on the EMS were set too high, and the EMS thought it wasnt possible to supply anymore fuel above what it had, so it imposed a fuel/ignition cut.
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
