ok here's my tale
Today on the dyno my car was given a run up with new turbo and new injectors with the old tune.
- 114hp @ wheels
- 10.1 AF.. or lower... 10 was the lowest on the scale
it was a no brainer that it was over fueled.
A quick adjustment of maps:
- 209hp@wheels@6000rpm
Nothing special, car had that in its previous stock form. However the turbo wasnt reaching boost till 4500 rpm, then slowly built up boost to 14psi.
- Finger was pointed at the EMS boost control solenoid being to slow to bring on boost.
The solenoid was sorted and boost was coming on at 3200rpm feeling stronger. BUT.. heres the but...
- Soon as the car reaches 5000rpm it seems like there is an ignition cut and stops the power.
We are scratching our heads as to why, New plugs were put in and gapped to 0.8.
- Rev cut is 7900 hard, 7500 soft
- boost Kpa cut is set at well over 1bar ... car hit 17.1psi at one stage earlier.
- boost when ignition breakdown occured was 12psi
Anyone got any ideas?
*Have been told*
- at higher boost pressure the spark plug electrodes can bounce resulting in ignition breakdown... (the tips close then open.. boucnce)
https://www.sau.com.au/forums/topic/27530-ignition-breakdown-techie-question/
Steve,
I am using BCPR6ES gapped to .8 minimum.
apparently the tips of these can 'bounce' under higher boost pressures and cause an ignition breakdown as i am expereincing. Have you got any input on that at all ?
I have been recommened by the shop to use Iridium ($20 per plug)
Up until today i have laughed at everyone who rushed out to use iridiums, as i saw normal plugs working fine, but to have this sudden break down has made me wonder....
Do not use iridium tipped plugs for forced induction applications. Our experience has shown them to be severely lacking when it comes to boosted engines. The tips usually break off then the plug is cactus causing all sorts of misfires.
i think they are gonna try some expensive ass plugs tomorrow :S
doubt its a coil pack, never had a problem before, and as stated, was running fine minutes before this current break down happened.
Dyno Day 2: No result
ok they put in iridiums, didnt fix the problem.
The car did 1 ramp and was nice and clean, BUT STILL ONLY 206hp on 11psi!!!! WTF
car went for another ramp... and the breakdown appeared again.
The place is pissed off and so am i. Platnum plugs are being tried tomorrow.
well if its not fuel, its most probably ignition.
I dont want to tell pork pies, but I have heard off this forum that the EMS wastespark setup was attributed to frying coilpacks. I have only heard of it the once.
As GTSt suggests, probably a good idea to be looking there next. If you know someone with a skyline see if you can borrow there coilpacks for a couple of dyno pulls - will soon enough tell you if that is where your problem is.
last dyno tune we swapped all coil packs due to a missfire
all coil packs were good... the miss fire was an error in their tune!
i am wondering about the actual ignition module now.
Also...
the 1:1 gear in my car is 3rd. Should the dyno run be made in 3rd gear, or is it 4th gear no matter what ?
ok for those interested:
The ignition break down was actually the car getting too much fuel! yet the AF were 12.1:1
Dyno guy took the car for laps around the block takeing fuel OUT!, said the car seemed heaps better and was running alot better.
Comes back to the dyno, does 1 ramp, 11.1:1 AF !!... taking fuel out made the car run richer! We are both stumped as to why this happened.
very weird indeed. Should have the car back end of today, tomorrow morning at the latest
yeah all sensors there.
My guessing is that somehow the fuel limits on the EMS were set too high, and the EMS thought it wasnt possible to supply anymore fuel above what it had, so it imposed a fuel/ignition cut.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
