Thanks, looking to join the club and do the DT.
I take it that Winton is one of the better places to do driver training?
First timers, like me, might want to take a quick look at this doc from the WRX forums
http://www.wrx.com.au/motorsport/Motorspor...es_for_2009.doc
  • Replies 167
Winton is a great track if your starting out. its a relatively low speed circuit, quite technical but with plenty of run off.
its a good one to develope your driving skills, they say if you can master winton, you can master any circuit! :(
Oh o :(
"Noise emission level is limited to 75dB(A) at 30 metres. Entrants who fail the drive-by 75dB reading will
get 1 (one) chance to rectify the problem and will be excluded if the car fails on a second reading"
Is this enforced at Winton? I thought they were a 95db track.
What's the go with accomodation, from what I can see there's only a few places left with those dates available.
I can see there's also a few self contained cottage things available for 77-105 a night which cuold be good if people are interested in sharing.
Hi Guys,
I'm looking to enter this event. It will be my first event with SAU (normally just drift with VDC). Whats the go with Rollcages? I read the entry form and it says the event is held under ASAA. But then read the rules and regs and it said it has to be cams approved, same story with harnesses too...
If anybody could clear it up for me that would be great!
Cheers
Rob
If anyone needs clarification on anything unclear in the supp regs, you will need to contact the motorsport director of the WRX Club - this event is run by them and they set the rules.
His name is Justin and you can get him on [email protected]
Just avoids anyone here giving you incorrect info and then you being disappointed on teh day - best to get the answer straight from the horses mouth.
We've booked a cabin and we're in with the rest of you so should be fun. We'll just be staying the Saturday night and will drive up in the morning on Saturday and meet you all at Winton.
All of my friends bailed on me so it'll just be me and the missus this time but if DECA shep was anything to go by there's more than enough friendly people around to make up for it.
Side note: The 18th is my birthday so I might be in fine form on the Saturday night :)
EDIT: As this will be my first sprint in this car and I barely know it I'm going to do Driver Training ;) Do you get to choose the Trainer?
Edited by ActionDan
Guest
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
