dunno wat brand u have but i have defi, water temp is direct screw in into my greddy top rad pipe, oil temp and pressure direct screw into my sandwich plate from greddy oil filter relocation, so u at least need a sandwhich plate for that, if your water temp came with a little bit of pipe with a hole in it, you need to cut into your water hose and put it inbetween with cable ties or clamps, should all be in the kit, unless u went budget guages ?
Easy enough to DIY, I did the exact same thing with the exact same gauges not a week ago.
You need a oil sandwhich plate and a rad hose thingo with a temp sensor in it.
If your NoR I dont mind giving you a hand, or you can come look at my setup and I can help you install ?
The Autogauge ones have a bit of an odd wiring setup.
Only other thing to note is with the top rad pipe setup and the sandwhich plate your better off doing a service at the same time, saves having to drop coolant and oil just to install them.
thanxs mate, 2 bad i live SoR :laugh: , wots a sandwich plate? where culd i buy a sandwich plate and rad hose temp thing?
cheers
  Douse said:
Incoming thread highjack:
What do you guys recommend for a good quality Oil Temp gauge? (besides DEFI cause that costs a small fortune)
Autometer.. I had Autometer mechanical gauges then upgraded to cheap electric gauges (Autogauge), now upgrading to Autometer electric gauges. The temp gauges aren't that pricey (~US$60 for 2-5/8" electric half sweep), but the full sweep oil pressure gauge is US$190 and the 30psi boost gauge is US$200 :) Going for Ultralites :)
  Gdekwant said:
not 100% where to get one from as the dude I bought mine off threw them in. Gimme a sec ill google some and see if I can find them.
cheers mate, i appreciate it. i got a sandwich plate today, prolli get the radiator hose adaptor thing 2morrow. just trying figure out how to connect the sandwich plate? :P
is it ok to connect all three gauges to the cigerette lighter or will this just cause a fuse to blow? where do u recommend i get the power source from? also, is it the oil pressure or oil temp gauge that connects to the sandwich plate or they both do?
cheers
Run 12V from somewhere reliable (hell even from the battery), fuse that line. Run to a relay and use the cigarette lighter feed to switch the relay.
That's the principle I used when rewiring my stereo, carpc, monitor and gauges.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
