Hi Guys
I have just recently bought a 90 model R32 GTR it ran well when i bought it home but now it feels like its starving of fuel about 4000 revs below that runs like a dream but when the turbo's really start to work it doesn't want to rev like it should and shutters a bit one of my mates thats a mechanic said it had a bad batch of fuel so i run the tank out and changed the fuel filter and its still doing it.
Any help on this problem would be great the motor is pretty much standard so is pretty responsive and goes really well to 4000-4500 revs than just starts to play up.
Help please
Kel
Edited by PTOOSH
https://www.sau.com.au/forums/topic/275339-help-please/
Hi Guys
Help please
Kel
where did you purchase this car, private or dealer?
it could be a no# of things, you sure this mate of yours is a mechanic and gave you a half arsed response like that?
so far from what your telling me...it could be:
Fuel pumps could be faulty and not supply enough fuel...
the Ingnition systm could make the car sluggish if at fault.
Check your ignition leads and plugs whilst your there and let us know
https://www.sau.com.au/forums/topic/275339-help-please/#findComment-4665152
I've had a bad batch of fuel a long time ago on one of my previous car and it really was noticeable. I remember past 6000rpms it just wouldn't want to go anymore. But it also affected the entire rev range not just a part of it.
Does sound like a pump/ignition problem.
Did 32 GTRs have knock sensors on the engine ? If it detects crap fuel, the computer will start retarding ignition at mid to high rpms when you're giving it.
GL
https://www.sau.com.au/forums/topic/275339-help-please/#findComment-4665170
Thanks mate i bought the car privately. And yeah my mates a light vehicle mechanic with work don't know how much he knows about imports.
It has a walbro 500hp fuel pump in it so it should be getting enough fuel but ill have a look at the leads and plugs.
Thanks for your help ill get back to you.
Kel
https://www.sau.com.au/forums/topic/275339-help-please/#findComment-4665179
before you do any of that stuff check all your cooler pipes for splits and loose clamps. mate had same symptoms, above 4000 shudder no power etc, was a cooler pipe clamp coming loose. When it hit boost it'd pop open, shudder etc, then when you back off it closes again. simple stuff before you mess with the sensors and other assorted expensive bits :P
https://www.sau.com.au/forums/topic/275339-help-please/#findComment-4666774
Damn hoses coming loose!
Thats why i mentioned the AFM. When i had a similar problem...they tell me the vacuum hose to the AFM had gotten disconnected so it wasnt getting the right reading! such a minor thing, so many major pain in the ass consequences =b
https://www.sau.com.au/forums/topic/275339-help-please/#findComment-4667382
Thanks guys had a look through it today and found one of the afm's was buggered and full of water looks like were on the right track thanks for your help really appreciate it.
Kel
https://www.sau.com.au/forums/topic/275339-help-please/#findComment-4668638
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
