How's it? I have fitted an RB20DET into my 180sx, to say it has not gone well is an understatement. I will tell you what has happened but I won't mention names.
I had the RB rebuilt standard, when it came to finishing off the engine mechanic no.1 asked for pics of the engine in magazines as he couldn't remember were hoses went. I also had to obtain torque settings for him as well. When it came time to start the car it idled but had no power. He asked me what the problem is (I am an electrical fitter and there is no mention of automotive mechanic on my ELECTRICAL license!).
So after I watched him scratch his head I sent it to workshop 2 who was told this is a rebuilt engine it idles but has no power and stalls after running a while. They diagnose it as ECU and I thought f*&k it install microtech. I am told that car is ready but is still low on power. I go to pick up car and the car won't start! After apologies and discussing with me, one thing I mention is that when mechanic 1 rebuilt the engine I asked how he aligns the cams (out of curiosity) he tells me that no.6 lobs face 180deg apart. This twigs workshop 2's curiosity, they check it out and do compression test, the result is 105psi! They check cams and lo-and-behold inlet cam 3 teeth retarded, exhaust cam 2 teeth advanced! I tell mechanic 1 and he swears that he checked it and offers to go and fix, but workshop 2 won't allow him into shop, insurance reasons. So I wear the cost to fix.
With the car running, I discovered that no.4 injector is leaking, turbo bearings are noisy (I knew that from the start), power steering pump is leaking at inlet, main seal leaking/trickling and some other minor stuff. I send the car back to mechanic 1 to fix these things up. He was the one who picked up no.4 injector was leaking so he fixes no.5, a week later he fixes no.4. The main seal was fixed no worries. Power steering pump was fixed, also he had to replace the power steer inlet pipe as he used the wrong type and the fluid was seeping out of the line, he fixed that. He replaces the turbo and assures me everything is kosher.
The next day the turbo again shit's itself! He assures me that oil was flowing in the turbo. The importer where we got front cut and replacement turbo now wants me to send it to turbo specialist as he doesn't want to keep replacing my turbo's, fair enough. So I send it back to workshop 2 as they are a performance shop and are a turbo specialists dealer. I am thinking oil starvation and so is the rest of Australia but this mechanic 1 assures me it is ok.
What in your opinion should I do? This mechanic 1 guy, if something comes up I don't hear about it till I ring him to ask if the car is ready. I obviously have to wait till I hear response from workshop 2 as I am also getting them to check other stuff out (more money out of my pocket), like engine compression mechanic 1 says it is at 140psi all cylinders which is very good for a turbo car (I thought 170psi?). And also the clutch, it has free play and is soft when cold and when it warms up the free play goes and the pedal becomes harder.
If it turns out bad (financially) what should I do? I took the car back to him as I payed him to do a job and I did help him with it (tickets on self everything I have done has turned out well, thermo's, fuel pump etc) so he did knock some labour price off due to this fact.
What do you think? Sorry for long post but you can't make this any shorter due to the shit I put up with. The disadvantage of it all is a mate introduced me to mechanic 1 and WAS sort of mates with mechanic 1. Thanks Pete
https://www.sau.com.au/forums/topic/27534-rb-conversion-not-gone-well/
Mechanic 1 sounds like a guy who works on commodores and fords and has no idea on the workings of anything outside that.
If he couldn't do the job properly at the start he should have said so. Though you have to give him credit for fixing everything and not telling you to get stuffed.
I'd hang in there, tell them you don't want it back until its running correctly.
It will all turn out in the end.
How's it? Thanks for replies folks, I have calmed down a bit since yesterday. The workshop it is at now has discovered I was given a dud turbo! The oil flow is sufficient, but they have offered a few suggestions that I won't go into. I spoke with workshop 1 again and they are willing to fix anything that needs fixing. For now I will leave it to that and I just hope it all works out in the end. Thanks again for allowing me to vent my frustration on the net rather than with a bazooka
Hey Omp,
Sounds like you have been a victim of bad luck or under-experience.....but I think the most important type of customer service is not whether something goes wrong, but how they fix it when they do.
It takes a big comittment for a workshop to fix stuff without charging you for it, its time they could be charging someone else for.
For sure. A previous car's gearbox wore out (oil wasn't replaced plus the box was given a hard life by the previous owner and then me), and I had the workshop I always took it to replace the box with a second hand one (not reco, but should be decent). That gearbox did not go well, it started leaking oil. Took it to a second workshop who thought the bolts were in the wrong places, thought hmm. Went back to #1 they threw it in the air and said woah the gearbox casing's cracked... that's a warranty repair fair enough. So they pulled the box out and replaced it under warranty. So after spending basically all my measly uni student spare change on that car at that workshop for a couple of years (and they weren't cheap) I finally got my moneys worth, the second box was great :(
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
