What The Hell
sneaky1
 Share
  • Replies 40
Posted Images
REPOST, that heap has been on ebay for ages.
Yep. Looking like that ... no one wants it. Would you? :down: Needs blue mesh!!!
The seller should invest in a respray (DIY) and will sell it quicker.
damnn that 32 looks abit... girly.. ahah
thats fkn hot
See the connection? :P
Edited by RubyRS4
^^if he puts blue mesh on he'll be lucky if he gets $100 for it
Somehow, I don't even think blue mesh would stand out on that as it is :down:
is that the car or did someone vomit all over my 42 inch LCD in the exact shape of an R32?
If so they are pretty talented, what a neat-o trick!!!!!!!
I'll give $2.50 and a pack of bubble gum for it right now. cash.
When I was shopping for a Skyline earlier, saw a white (I think it was) 32 with so much red in the interior it hurt my eyes :P
rule 32 Ruby: you must have pictures to prove your statements.
Fine. I just cleaned out my "Ended" list, but see if he relisted.
  • 4 weeks later...
 Share
    • Yes, it's similar length.
    • Is the CD009 similar length from bell to shifter?    car will just be for the street with the odd track day. It’s RB30det, and weighs about 1000kg
    • The r34 gearbox is like $3400/3700 landed from Japan sometime last year.   Contact jessestreeter.com for info and quotes. From memory the navara gearbox needs input shaft machined down as I looked into a while back and there's a thread somewhere here from 2018-2021 about it. Depends on what your doing with the car maybe worth the dollars to go cd009 or a 8hp50/70.
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
