Hi
Selling my 1992 Nissan Silvia in excellent condition inside and out, NEVER been in an accident. Have receipts for most if not all work carried out, most of the parts on the car are practically brand new and have very low mileage on them as the car is only used on weekends. Engine has about 8,000 km on it and has had a pretty easy time, mostly dyno time and weekend driving. No track time or circuit work at all.. have receipts for build and previous tunes, service and maintenance
The car was resprayed a few years ago and is in mint condition, paint is really good with no chips or dents
No swaps, just chasing a cash sale
$15,000 with rego till November
$15,500 with rego till November and Victorian RWC
GARRETT 2871R 52T .64 * Less than 500 km old with receipts
EARLS braided water lines * Less than 500 km old with receipts
Braided oil flow line with SPEEDFLOW fittings * Less than 500 km old with receipts
Standard turbo manifold with 7 layer S15 SR20DET exhaust manifold gasket * Less than 500 km old
All genuine Nissan gaskets used on turbo side, dump, turbo to manifold, comp inlet & outlet etc
Deleted air con including condenser, lines, pump & idler pulley as well as bracket
ARIAS forged pistons
EAGLE rods
GREDDY 1.2mm metal head gasket
GREDDY IN 264' & EX 272' cam shafts
GREDDY valve springs
TOMEI rocker arm stoppers
Ported & polished head
VISION adjustable CAM gears
TRUST style high cap baffled SUMP
DRIFT oil catch can with black lines
Z32 AFM meter
BLITZ LM pod filter
GREDDY drag 600 x 300 x 115 intercooler kit
ASI 52mm twin core alloy radiator
APEXI Power FC
GIZZMO MS - IBC boost controller
HKS EIDS
BLITZ 850cc side feed injectors
WALBRO 600hp in-tank fuel pump
GKTECH TOMEI style dump * Less than 500 km old with receipts
GKTECH HKS style 3" flex front pipe * Less than 500 km old with receipts
JJR decat pipe
Custom stainless diff back with MAGNAFLOW rear muffler * Less than 2,000 km old
GKTECH over flow bottle
OGURA single plate clutch & flywheel
CUSCO front strut brace
CUSCO rear strut brace
HSD HR coilover * Less than 1,500 km old with receipts
200SX front & rear hubs
R32 GTR front calipers
EBC green stuff pads front
EBC street kevlar pads rear
Braided front brake lines
DBA 4000 slotted front rotars
DBA slotted rear rotars
GKTECH Tie rod end spacers *Brand new but not installed
GKTECH Alloy steering spacer *Brand new but not installed
CST HYPER ZERO 1 BRONZE - *Brand new
F: 17 x 9 + 22 (8 mm slip on)
R: 18 x 9.5 + 15
I just bought the wheels from Japan last week and they are on their way here, hopefull arriving within the next 2 weeks. Car will be sold with the new wheels and tyres will be provided upon sale
240km speedo
NISMO black chrome shift knob
SAFETY 21 - 5 point roll cage
BOSTIN Acoustic front speakers
FOCAL 165 CA1 6.5" rear speakers
SONY CDXGT271 head unit
S13 factory aero genuine side skirts * Not fitted but will come with car upon sale
Tinted windows
Professionally rolled rear guards
Tuned by Trent @ Status Tuning on June 3rd 2009 * Have receipts and dyno graphs
234.5rwkw on 18 psi
417nm torque
Cage has been installed with all standard interior trims and seats so it sits in nice and tight and looks mint. Looks almost factory as the side trims have been trimmed down accordingly. This is not some backyard built Silvia like you see with some if not most of the other cars on the forums. Engine has been professionally built by a reputable work shop with top quality parts, tuning done by the best, always used top brand/quality oils, coolant, gaskets, fuel etc All work done on this car is top quality and I haven't cut any corners or spared any expense
This car is one of the cleanest if not the cleanest and neatest silvia around! Check it out for your self
Please PM any interest and don't post in the thread, alternatively call or SMS 0416 623 381 ANYTIME just no private callers
Thanks :down:
https://www.sau.com.au/forums/topic/275386-1992-nissan-silvia-perfect-example/
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
