Hi all,
Im putting in a new head unit in my brothers Volvo haha V40. Went with entry level alpine unit with hi-speed ipod control from Tonkins (cheers Ben :) )
The old unit didnt have a constant power to it just to acc powers and 2 grounds (WTF stupid germans). Where will be the easiest place to steal constant power from? The ciggie lighter is acc aswell :P Im thinking maybe the ignition itself would be the shortest to run a cable and their must be constant power their. Any ideas?
I really CBF running a line direct from the battery and fusing it...
Also the stock headunit controlled all 6 speakers (4 2 ways i think and 2 tweaters) the alpine unit ive hooked up to the 4 speakers is their anyway i can hook up the tweeters aswell without buying more gear cos hes a full on tight ass when it comes to his car. as long as its got fuel and a few empty iced coffee cartons floating in it he's happy :down:
Cheers,
Chris
https://www.sau.com.au/forums/topic/275391-head-unit-install-in-brothers-car/
Hi all,
Cheers,
Chris
wrong area mate
http://www.skylinesaustralia.com/forums/Ca...ecurity-f9.html
post audio here
the car has two grounds????, one is a light switch which shows ground until the lights are turned on, then goes to 12volts if you use a test meter ?
this is a volvo wiring diagram, check your model here
http://www.volvoclub.org.uk/faq/MaintenanceManuals.html
Main radio harness 13-pin connector (for large 14-pin radio connector):
pin 1 (brown/white) left dash speaker (+)
pin 2 (grey/red) right dash speaker (+)
pin 3 (brown) left dash speaker (-)
pin 4 (grey) right dash speaker (-)
pin 6 (yellow/white pair) night dimmer (from headlight switch & relay)
pin 7 (white) dash dimmer (+) (connected to dash lighting rheostat)
pin 8 (blue) dash dimmer (-)
pin 9 (green/red pair) +12v from battery (and to optional CD player)
pin 10 (black pair) chassis ground
pin 11 (orange) +12v from ignition (via fuse 14)
pin 12 (green/grey) power antenna motor control output (switched on/off with radio on/off) or power for in-window antenna amplifier (see note below)
pins 5,13 (not connected)
Speaker harness 13-pin connector (from small 10-pin radio connector):
pin 2 (green/orange) left front door +
pin 6 (orange/black) left front door -
pin 3 (orange/white) right front +
pin 7 (black/orange) right front -
pin 8 (blue/pink) left rear +
pin 12 (brown/pink) left rear -
pin 9 (pink/white) right rear +
pin 13 (pink/black) right rear -
pins 1,4,5,10,11 (not connected)
funny enough I answer questions in the audio forum part, and so does chris rogers and a few others...lol
http://www.the12volt.com/installbay/vehicl...eard/Volvo.html
your guide is located here, pm me if you need help still, cheers
see it says Chasis ground plack pair?
So i should look for green/red for the constant 12V
What about the illumination/dimmer on the unit what one of those do i use?
mate , use a multimeter to test it, guides can be wrong and I take no responsibility if you fry a radio, set off the airbag, or toast the car computer with a test light.
if your not sure have it installed by a pro installer. what part of town do you live in ? I might be able to test the wires for you time permitting?
Jack 88 on here does mobile installs, pm him
check to see if you have a dash clock, dome light ? I would suss you have a blown fuse off the constant power wire. you dont need to run a wire to the battery on new car?
check the fuses
is there anything else on the dash that doesnt work ? or has anyone hacked up the harness before ?
if all else fails, I would take it somewhere to have it looked at, to cut into the main harness to solder one on is best left to someone who knows what to do, there is a wire in the steering wheel area and possibly elsewhere depending on the year that contains the airbag, ground it out and bang the airbag goes off with your face mm from it.
best of luck, but check the fuses as above , if the car electrical is working properly, you shouldnt have trouble finding constant power near the radio
do not circumvent a fuse,or increase the amp rating .. fix it right or risk fire
