The R32 N1's all have a different chassis designation to standard GTR's
The main way to spot it is that the second last letter is a Z.
Fro example mine is (on the Nissan build plate, not Aus compliance sticker)
KBNR32RXFSZN
The last letter, in my case N was used on all N1's pre 93, however the N1's after 93 which were based on V-Spec 32's all have a different last letter. (actually i'm checking this now could be one of the other letters that were different on the V-Specs)
*edit*
here we go
KBNR32RXFS-ZN for the car made 9108-9302
KBNR32RBFS-ZN for the post 9302
Cheers
https://www.sau.com.au/forums/topic/275396-real-n1/#findComment-4666073
Id guess your talking about this one;
http://www.my105.com.au/classified.asp?id=12132
If so, and you want more info, send a pm to "Marlin". Shame i dont have $65k spare, id be all over that like a rash.
There's not many N1's floating around, here's another though;
http://www.my105.com.au/classified.asp?id=6723
https://www.sau.com.au/forums/topic/275396-real-n1/#findComment-4666284
PS - if looking at that ex Whites R34 for any motorsport then budget an extra $10K to replace the White Hot Motorsports brake set-up. Everyone who has owned that car since has complained about massive pad knock-off and it can only be as a result of those dodgy home made brakes. LOL
I don't know why they keep doing it. The had to give up the chase at Targa this year with the Lambo as their brakes gave out again.
https://www.sau.com.au/forums/topic/275396-real-n1/#findComment-4666534
Who needs brakes? Remember, I ain't that quick.
https://www.sau.com.au/forums/topic/275396-real-n1/#findComment-4667247
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
