Hey currently running 10-40 semi synthetic penrite, done 5000km and still honey clean.
Gearbox using vtx castrol 70-90 but thinking of changing to Penrite sin 75-85.
Seems like an ok combination? Does nissan sell genuine oils for at least the gearbox?
What a good oil to use? Mainly interested in gearbox oil.
https://www.sau.com.au/forums/topic/275419-what-oil-for-engine-and-gearbox/
I was about to ask the same question about 34 Gearbox oil, but mine is a little more troublesome. After some hardcore dyno work i noticed 4th was an issue, later followed by bearing type noises in 2nd & 3rd gearshifts and also sometimes at idle.
Some damage is obviously present on 4th, whether its glazed of not i dunno, but i want to know what it that "good oil" you hear about when somebody mentions a few box drama's?
Need to know ASAP as the car is not being driven at the moment. :down:
Just get it fixed Matt...a heavier viscousity oil (85w140) may silence the problem for you, but it will come back in 5-10,000km and may cause even more damage by then. Sounds a bit like a cluster bearing to me.
Yeah, i know what you are saying... But i need to keep it going till the $$$'s are available. I might try the Redline Shockproof stuff and see what happens?
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
