In case anyone is interested, this is a good write up on restoring the headlight lens. I remember this being discussed some time ago but thought it might help other members with regards to the hazy lens that the V35 tend to have over time due to oxidation.
I myself have used PlastX in the past with considerable success. The article covers the use of grit pads and some photos.
http://www.canadiandriver.com/2009/06/18/p...tion-system.htm
Cheers.
Rob
https://www.sau.com.au/forums/topic/275428-restoring-headlight-lens/
I am not 100% sure on this, but if my memory serves correct all headlight have this UV coating which prevents the oxidation, once the UV coating goes the oxidation comes back, so the headlight polish acts as a sealant....so the question is, while the sealant will keep wearing off, isn there a way to restore to factory specs?...sm sort of 'UV' spray?
But yeh, i dont have a drill with RPM rating :P , and my lights are kinda hazy...prob go for the PlastX kit.
Mine have gone yellow as well....And I have been told to use toothpaste, water and a rag...I will try it on my V35 when I get hold of it soon...but in the meantime, I'll do it on the Mrs Mazda 3....hehe, wish me luck....
here's another product, and available in Australia!!!
http://www.glassylite.net.au/webspecial.ht...CFc0vpAod9kC1qQ
I've emailed the guy and asked for a money-back guarantee if I decide to buy it. Will wait for a response. If it works, I'll let you guys know.
Edited by siu_loong_bao
I'm very interested to hear the outcome as i have had a detailer come and buff mine out with an electric buffer with no success. Mine seem to have gone through to the inside so there's really no helping me i think. The only thing i can think of is to take it off and clean the inside but i really dont want to go through the process...
Hi.
I presume you are discussing the outside of the covers if so dont waste your money buying overpriced products. Simply go to the supermarket buy a tin of Brasso take it home give it a good shake pour onto cloth start rubbing. You may be very surprised at the result. Sometimes the old products are the best.
Let us know the results if you try it.
I was just thinking...in the process when the headlight is wet sanded the UV protection is removed and thus oxidation occurs, to prevent this you wax it to for a layer....but instead why not use a clear film, not just any cheap one a 3M one, i used their vinyl on a couple of cars and they stick very well and stretch very easily around curves using heat.
if i do go the wet sanding process i will try it out with some clear 3m film.
A mate of mine used the Glassy Lite product a couple of years ago on his Soarer and he tells me that it worked really well. I haven't needed to do anything with my light yet, but if I did, he has been recommending Glassy Lite to me.
He said that with my lights being as new as they are, I could probably get away with just using Step 2 and 3 in the instructions as Step 1 is quite abbraisive and is best used on lights that are very dull. This is to keep them good, a preventative. I have seen his lights now, about 2 years on, they still look pretty good, although he does do maintenance on them every now and then.
if this glassylite guy doesn't respond to me email enquiry by the end of this week, I am going to buy myself an aftermarket headlight set from the US....
But then you hit the never ending issue of the lights being lopsided...like the majority of the beam pointing out and hitting on coming traffic...do a search, there has been a extensive discussion about them. Also the fact they are ridiculously expensive, better to try using an abrasive method (sandpaper, brasso etc) and put a thin high quality clear film to protect the lights...well, forever.
Tai, so tell us how u went about doing it on your car with some pics...An Aussie version would be most appreciated (versus the canadiandriver.com link)... :D
And where did you buy the clear 3M film?
Tai, so tell us how u went about doing it on your car with some pics...An Aussie version would be most appreciated (versus the canadiandriver.com link)... :blink:
lol i will be doing it soon, hopefully in the end of next month...and about the film, you can contact 3M and they will point you
to the closest dealer...but ill prob pay a visit to a friend who i bought the vinyl for my black roof overlay.
Will be sure to update.
I do part time detailing as my 2nd job and have done heaps of headlights on my mates car yard. I have only failed once on the headlights and that was due to the fact the headlights were oxidised on the inside so the only way to polish it was to crack open the lens.
If there's enough interest I can do everyones headlights on a weekend, but we need to find a suitable venue with a power outlet and enough space for parking cars.
Also i can advise what products to use to prevent oxidising again with several sealant products.
Normally I charge about 50 bucks but if there's enough interest, i'll do it for half price. If I cant fix it, wont cost anything.
I suppose it's only a Sydney 'groupie' thing....poor us Melb blokes...LOL
Well, I am keen to hear about who has already cleaned up their V35 lights and what they used, etc...
I was just about to click the 'buy it now' button for a 3M headlight restoration kit from the USA last nite too...I guess i can wait and see for a cheaper alternative. the 3M Kit is not cheap!
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
