hey i have just bought a r33 gtst s1. 3'' exaust, hks pod filter, an b.o.v.. running 12psi. iv had a prob with the cars revs dropping really low after boosting it up an giving it a bit.. an every now an then it drops so low the car konks out.! it willnot start again for a few min then drives fine for a while then dose the same thing again evry now an then.. driving me crazy. i changed the fuel filter but still dose the same! fuel was clean an filter was clean to..? has anyone had the same problem.. id love abit of advice.. thanks. :P
https://www.sau.com.au/forums/topic/275451-r33-gtst-konking-out/
hey mate i had a similar problem and it maybe ether of there 2 things the crank angle sensor (cas). if you have a mate with the same car or some one that you could lend it off just to try it. just mark it swap them and try it. or you can clean your aac valve but this usually only will conk you out when you go down to idle. if it is all carboned up when you let go of the accelerator it will just die on you.
well it is a bit confusing sorry about that but i hope this can help you out cheers
yer that is what happens.. after boost when i slow down to say a speed hump
at idle it just dies on me.. 1-2min later it will start up.. i think ill try that it sounds like that could b it..! cheers mate.
If no luck on the AAC, clean the AFM.
yer i cleaned aac out.. cleand afm.. replaced fuel filter too.. stalled on me today while driving at 60km...? what the hell.. 2min later starts up fine.. if its not bov.. maybe fuel pump.? dont enjoying stalling at major intersections much..!
Im guessing the bov is venting to atmosphere? looks like thats the problem if it is.
yer it is.. might move it an see how it gos.. if it still happens im going to go nuts.. not loving stalling every time i drive !
Another issue I came across once that was similar to this was that there was a loose wire on the ECU harness.
Just to cover all bases, remove the kick panel, start the car and GENTLY wriggle the ECU harness and see if the car cuts out.
sweet ill give it a go..
man..! started the car up an let it idle for 2-3min an it just died an stalled.. starting to think its the fuel pump.. had to get it towed.. just kept getting worse an worse.. then it woulnt even start to drive onto the toetruck..!!!!!!!!!! hoping its the fuel pump..! strange but.! :)
Symptoms point to the pump as a possibility, very common for the old R32 pumps to die, since it's a early 33 the stock pump might be nearly 15 years old now
yer.. hoping soo ill keep yous informed.. hope to get it back monday or tuesday after the boys down the shop do all the tests an stuff on everythig..
well turns out it was the fuel pump..! so its all good now.. sweeeeet.. :down:
HOLY CRAP!!! I thought i was the only tard to stop at a major intersection, holding up Melbourne's traffic. Great FUN! So the fuel pump solved your problem. I'm gonna get one on Wednesday see how I go.
P.S I feel your pain!
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
