VERY HARD! only Just Car might consider that. You would have to let them know the colour.....
That car probably looks normal to you while hiiiiigh. Sure it has awards but I think it's hideous
Edited by Topaz
I'd check the catch can for legity (must drain back into the sump), check it has a cat, make sure it isn't too loud, swap the suspention and wheels, and it should get over.
Having said that, absolutely horrific colour! I'd much rather your RB30 R34. And I thought you were selling it to buy a house?
they dont need to drain back to the sump, just cant vent to atmosphere.
i cant see much why it wouldn't pass, there are no real big issues with it.
i highly doubt the pits will pick up the twins, especially being low mount.
Yes i am still buying a house......and a car lol
this car is highly unlikely to ever get registered and if it were to you'd need to know someone that can provide updated permits for the mods and even then, unless you know someone thats on the pits i wouldn't waste my time. I've imported a skyline from Melbourne that had 250rwkw and that was hard enough as it was, once you start upgrading the turbo's they don't want you on the road. Don't recommend it mate, it will take a lot of time, a lot of money and in the end might get you no-where!
nah i dont think i want to bother with it because i really think getting it over the pits would be a nightmare! More trouble then its worth. Thanks for the heads up guys. But i found another 99 GTR R34 V-spec midnight purple III with 37k km, stock, only 1 owner from jap, orginal log books mint condition. Dealer is asking $62K. What you guys think? Is it worth it? I could get another cheaper but i really like this colour. He said his basically getting his money back because his got another 3 GTR's and he just wants to turn over the stock.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
