Pretty much as per topic, I literally have a bedroom filled with car parts and some of them have to go if I want my girlfriend to still visit me :P
R33 T28
Picked up a couple of turbos in my quest to find one to suit my SR20DE+T project and the exhaust ratio isn't quite what I want so I bought an ex S15 ball bearing instead :ermm:
Anyhow, before I owned it I was assured it came off a low kilometre car (he said around 50,000 kilometres) and is very, very clean.
No shaft play.
No oil anywhere it shouldn't be.
Has spent two months in my bedroom and has always had all inlets covered - just in case.
Oil/water lines attached.
Wastegate actuator looks to be good.
The only thing I can think of is that the housing has been rotated. Nothing major. One or two non-essential bolts missing.
Seems to be in really good condition - I haven't had it running though.
$400 ono + postage.
4 X 370CC U13 SR20DET Injectors and rail
Not much to say. Were on a running car, are apparantly identical to Silvia injectors. I have bought Nismo items so they are no longer required. Has fuel pressure regulator attached. Injectors are clean.
$150 ono + postage
Pulsar GTi-R Exhaust Manifold
Another clean(ish) item. Bog standard. No longer required as I have another getting heat coated as I type.
Stock cast manifold. No cracks/dents etc. Bit dusty, has been sitting around for a while.
$150 ono + postage
Pics up shortly however they are essentially as described. I am negotiable on prices and if you are local enough (hobart/launceston) I will personally drop them off for you.
Cheers,
Claye
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
