Parting Out R32 Gts-4 Coupe
Item:
Nissan Skyline R32 GTS-4 Coupe
logan, qld
Website:
this
Item Condition:
lots of good parts
Reason for Selling:
not needed
Price and Payment Conditions:
bootlid with spoiler - $140
rear bumper - $50
tail lights - $150
front seats pair - $150
rear seats - $100
dash with air vents (all in MINT condition) - $300
headlight and wiper stalks - $60
clutch and brake pedal (perfect for manual conversion) with clutch master cylinder - $200
digital climate control - $50
drivers window switch - $50
passenger window switch - $30
lh door complete (with window switch, glass, trims etc) - $100
lh rear quarter glass -$50
5 stud conversion (front and rear calipers, discs, handbrake cables) - $950
RB20DET complete with AWD gearbox (turbo, all mounts, harness etc) - $2200
Intercooler piping to suit RB20DET - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread - $700
Damper adjustable supension - $300 (rhr is bent)
Full exhaust 3" dump pipe to cannon muffler with hi flow cat - $350
HEAPS OF PARTS - if you need something, ASK as I may have it
Extra Info:
ALL PRICES ARE ONO
Pictures:
will be up over the weekend
Contact Details:
PM or Call/SMS 0401 121 962
  • Replies 41
Posted Images
Jimmy - I have headlights from a 32 4 door so yes, have headlights
TRB001 - pics will be up tonight of rims
jonn - diffs will be sold complete - will work out pricing for you once removed
Steve - I've got 2 exhaust for 32, one complete, one needs dump pipe. both hi flow cats, one has cannon exit, other has twin hotdogs.
ALL PICS TO BE POSTED TONIGHT
true true, id want the one with cannon, but dont need a dump pipe. just msg me on msn or send me a pic via pm if u can bro. thanks
UPDATED PARTS LISTINGS AND PICTURES
lots of good parts
Reason for Selling:
not needed
rear bumper - $50
tail lights - $150
rear seats - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread (toyo teo plus 235/45r17) - $800
Interior trims from $10 - just ask what you need, will let you know
White handbrake boot - $30
splitfire boost gauge - $30
steering wheel - $100 (has been retrimmed, but MINT condition)
Pictures:
dash and window switches
rims
bumper, boot lid, taillights
taillights
rim close up
tread left on tyres
handbrake trim
steering wheel
steering wheel
steering wheel
boost gauge
sunroof and roof trims
dash
Any chance that you have the accelerator cable and is the Gear stick rubber boots in good cond, no cracks in the rubber?
How much posted to Brisbane 4055?
im located at 4133 - so pick up is available saves postage
accel cable - $40
gear stick rubber boot ?? are you talking the one that sits around the top of gearbox, shifter into top of gearbox??
or the cover around hole for shifter to come through tunnel?
Im gonna need it posted, have no licence atm :)
I want the one thats bolted to the tunnel with the 4 10mm screws and the one thats under that, which attaches to the gearbox itself. Aslong as they have no cracks or splits ill take em and them and accelerator cable to.
I dont need the trim bit that clips into the centre console.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
