Parting Out R32 Gts-4 Coupe
Item:
Nissan Skyline R32 GTS-4 Coupe
logan, qld
Website:
this
Item Condition:
lots of good parts
Reason for Selling:
not needed
Price and Payment Conditions:
bootlid with spoiler - $140
rear bumper - $50
tail lights - $150
front seats pair - $150
rear seats - $100
dash with air vents (all in MINT condition) - $300
headlight and wiper stalks - $60
clutch and brake pedal (perfect for manual conversion) with clutch master cylinder - $200
digital climate control - $50
drivers window switch - $50
passenger window switch - $30
lh door complete (with window switch, glass, trims etc) - $100
lh rear quarter glass -$50
5 stud conversion (front and rear calipers, discs, handbrake cables) - $950
RB20DET complete with AWD gearbox (turbo, all mounts, harness etc) - $2200
Intercooler piping to suit RB20DET - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread - $700
Damper adjustable supension - $300 (rhr is bent)
Full exhaust 3" dump pipe to cannon muffler with hi flow cat - $350
HEAPS OF PARTS - if you need something, ASK as I may have it
Extra Info:
ALL PRICES ARE ONO
Pictures:
will be up over the weekend
Contact Details:
PM or Call/SMS 0401 121 962
  • Replies 41
Posted Images
Jimmy - I have headlights from a 32 4 door so yes, have headlights
TRB001 - pics will be up tonight of rims
jonn - diffs will be sold complete - will work out pricing for you once removed
Steve - I've got 2 exhaust for 32, one complete, one needs dump pipe. both hi flow cats, one has cannon exit, other has twin hotdogs.
ALL PICS TO BE POSTED TONIGHT
true true, id want the one with cannon, but dont need a dump pipe. just msg me on msn or send me a pic via pm if u can bro. thanks
UPDATED PARTS LISTINGS AND PICTURES
lots of good parts
Reason for Selling:
not needed
rear bumper - $50
tail lights - $150
rear seats - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread (toyo teo plus 235/45r17) - $800
Interior trims from $10 - just ask what you need, will let you know
White handbrake boot - $30
splitfire boost gauge - $30
steering wheel - $100 (has been retrimmed, but MINT condition)
Pictures:
dash and window switches
rims
bumper, boot lid, taillights
taillights
rim close up
tread left on tyres
handbrake trim
steering wheel
steering wheel
steering wheel
boost gauge
sunroof and roof trims
dash
Any chance that you have the accelerator cable and is the Gear stick rubber boots in good cond, no cracks in the rubber?
How much posted to Brisbane 4055?
im located at 4133 - so pick up is available saves postage
accel cable - $40
gear stick rubber boot ?? are you talking the one that sits around the top of gearbox, shifter into top of gearbox??
or the cover around hole for shifter to come through tunnel?
Im gonna need it posted, have no licence atm :)
I want the one thats bolted to the tunnel with the 4 10mm screws and the one thats under that, which attaches to the gearbox itself. Aslong as they have no cracks or splits ill take em and them and accelerator cable to.
I dont need the trim bit that clips into the centre console.
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
