Parting Out R32 Gts-4 Coupe
  • Replies 41
Posted Images
bootlid with spoiler - $140
rear bumper - $50
tail lights - $150
front seats pair - $150
rear seats - $100
dash with air vents (all in MINT condition) - $300
headlight and wiper stalks - $60
clutch and brake pedal (perfect for manual conversion) with clutch master cylinder - $200
digital climate control - $20 (missing some buttons, but good to buy if you need to fix your own buttons)
drivers window switch - $50
passenger window switch - $30
lh door complete (with window switch, glass, trims etc) - $150
lh door glass (only glass) $100
lh rear quarter glass -$50
rh door glass (only glass) $100
5 stud conversion (front and rear calipers, discs, handbrake cables) - $950
RB20DET complete with AWD gearbox (turbo, all mounts, harness etc) - $2200
Intercooler piping to suit RB20DET - $100
Stagea AWD computer - $50
17x8 +35 , 5x114.3 chrome wheels with tyres 60% tread (toyo teo plus 235/45r17) - $800
Full exhaust 3" dump pipe to cannon muffler with hi flow cat - $350
Interior trims from $10 - just ask what you need, will let you know
White handbrake boot - $30
splitfire boost gauge - $30
steering wheel - $100 (has been retrimmed, but MINT condition)
sunroof with all trims - $300
door mirrors pair - $100 (will sell individually $60 each)
RH headlight - $40 ( mount broken, but apart from that MINT condition)
RH corner lamp GTR style - $50
Space Saver tire - $50
AFM (pink label) x 2 from series II RB25 - $80 each
Front Windscreen (factory with built in aerial - $200
Rear Windscreen - $150
Rear wiper - $50
Gearbox tunnel boot - $50
HEAPS OF PARTS - if you need something, ASK as I may have it
Pictures:
front screen
taillights
handbrake boot
steering wheel
boost gauge
17x8 +35 wheels, with 60% + Toyo Teo PLUS 235/45R17
Intercooler piping and hi flow cat convertor on exhaust
exhaust
side mirrors
lh door
dash and interior
PLEASE NOTE - i have discovered that this IS NOT RB20 it is actually a RB25 after finding the car running a series 2 rb25 AFM and running a stagea manual ECU. Any stagea owner wanting to convert their car to manual, or any one with a 33 GTS4 wanting to convert their car. Also does run the RB25 turbo aswell. original post HAS been edited so please understand reason for price changes, this also means, anyone wanting to convert their stagea to manual, i have also listed that in parts for everything you will need.
DUE TO SAU PLEASE FIND BELOW UPDATES ON PARTS AND PRICES
Item:
Nissan Skyline R32 GTS-4 Coupe
logan
Website:
this
Item Condition:
lots of good parts
Reason for Selling:
not needed
Price and Payment Conditions:
rear bumper - $50
tail lights - $150
rear seats - $100
RB25DET complete (minus pwr steer pump) with AWD gearbox (turbo RB25, all mounts, harness etc) - $3000
RB25DET complete (minus pwr steer pump) with turbo, mounts and harness - $2000
AWD GTS4 gearbox, clutch and brake pedal, and clutch master and slave, clutch, flywheel, all bolts for manual conversion and gearbox mount, ECU - $1700
Intercooler piping to suit RB25DET - $100
Stagea MANUAL ECU AWD computer - $150
Rear wiper - $50
Extra Info:
car has 158xxxkm
engine is UNKNOWN as it has been changed. car was originally a personal import from Japan, so conversion could have been done in Japan. buy more then one item, and will discount total price.
Edited by slippery sliders
  • 1 month later...
front and rear windscreens are still available
dont have the breather pipe on the top of motor
shell is well bent so will be going to the wreckers
air con compressor - $50 but you pay for postage, unless you can pick up.
no headlight lh, only rh and indicator/parker
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
