Hi all,
I'm currently running greddy 8's in my RB26 which are made to JIS (slightly longer plug when compared to ISO). The NGK BCPR8ES are also made to JIS but I can't seem to get them here in the UK. They only do 6's and 7's and I need to colder grade (600bhp 1.5 bar HKS 2860 7's). Does anyone know if they are still made, I've been told they are discontinued.
I've tried BCR8ES & BKR8EIX but both of these give really bad hesitation, my guess as they are shorter ISO. With the Greddy plugs it was completely fine, it started to get a intermitent mild hesitation low down coming on boost so I thought spark plugs could do with a refresh whislt not looking that worn. I swapped plugs for the slightly shorter ones, still grade 8 and it was 10 x worse so I attributed the hesitation to spark plugs?
Car is running spitfire coilpacks. When I drive the powerfc is setting off the cat light when it hesitates even just plodding around slowly, barely on boost. I know the light flashes either if you have maxed injector duty, too much knock or air flow. Knock levels were reading high around 40, I thought powerfc flashed if it was above 50? My car does have agressive cams and makes a bloody lot of noise but am still concerned as to what it could be.
The car also won't idle properly anymore, it used to be around 1100 with very lumpy idle but now it struggles at 800 and tries to stall all the time. I'm going to try the old plugs to see if it makes a difference with the hesitation and will report back.
Thanks,
M
https://www.sau.com.au/forums/topic/275492-spark-plug-problem-help-needed/
I don't like the splitfire coil packs personally. I have tried them in a couple cars. The cars always ran better and had less misfires with the splitfire coils in them.Some people like them, or they help as replacing 10 year old parts with newer parts does often work out.
I like new OEM coils, replaced fairly often as they cook in the valley of the engine.
The harness also cooks. They get crispy over time, and need to be replaced also.
One thing to check before you go too far. Check each plug for the contact to the top of the plug. I have had a couple recently that were missing the spring/carbon. They would run ok until they got some load or heat into them.
Hey mate thanks for the fast reply.
I've just tried the old plugs, still just as bad. When I rev the car on idle it hesitates, after 4k it clears kind of but a real mission to get up there due to stutter.
I'm getting lots of knock just from reving on idle, when it hesitates it knocks and the dash light flashes as power fc is detecting knock around 3k. Does this give any clues if its knocking?
I'm thinking dodgy mafs as she now struggles to idle and i'm getting knocking maybe from lean conditions, that's what a dodgy maf did on my scooby, any ideas??
M
Edited by Monky
go see a mechanic something is wrong
suggestions
mangled timing
mangled crank sensor
mangled tune
mangled cas bolts
and so on. it shouldnt known mega aggressively at 3k unless something is seriously wrong
check the basics, check timing, check cam belts, check cas, and then go see a mechanic
Thanks for the info defo going to get it looked at as unsure what else it could be.
I thought though when a MAF/AFM fails it effected idle and would also give lean conditions, this was a common problem on the Scoobies. I did clean my AFM's with carb cleaner and may have gone a bit overboard. Regardless I have Z32 MAF's on the way as the current ones are silconed where they have cracked and fell apart when I took them apart!
Once I have the new Z32's it will need a remap so will get everything checked and leave her to rest for now.
M
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
