OK REALLY NEED THIS GONE ASAP! NO MORE TIME WASTERS! HOPEFULLY I DONT NEED TO POST THIS UP AGAIN CAUSE THIS IS A STEAL
PICK UP A BARGAIN! $9,900
1989 hcr32 skyline
custom metallic brown (respray by custom propaint)
142,000km's on the chassis
all mods done between 135,000-140,000km.
just serviced. oils.
new pads and rotors.
new battery
rego till 22nd july.
front mount intercooler
aftermarket pod filter
garrett gt3071r- turbo (DUAL ball bearing, .71 avoworld rear housing)
aftermarket dump pipe
3" zorst to twin 2.5" with hotdog makes a very nice note straight from the turbo.
z32 AFM
bosch 040 intake fuel pump
SARD 800cc injectors
remapped computer
5spd manuel rb20 box
heavy duty clutch
isotta shortshifter with trust gear knob
ISC N1 Coil overs
turbosmart eboost2 electronic boost controller.
autometer boost gauge and battery mounted on drivers arm.
blitz turbo timer
pioneer head unit
clarion rear 6"
working very well air conditioner (climate control)
R34 Gt-T Front Seats
remote central locking, immobilizer and fuel cut.
AVS 17" black rims with new tread all round
It's located in adelaide.
pics:-
rear
front
interior
Interior shot
Interior Shot 2
Interior Shot 3
Back seat
Front
Front 2
Back end
Back End Close up
Engine
Another Front on with bonnet up
Another Front Close up
Zorst straight pipe
PRICE:
$9,900 o.n.o
contact me by phone.
0433703155 (no joy riders, time wasters)
https://www.sau.com.au/forums/topic/275502-bargain-r32-skyline-9900/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
