I have too much stuff in my garage and house that I don't need.
Everything is in used condition unless stated otherwise.
Melbourne pickup is preferred but can send smaller items interstate if postage is agreed.
**I'm trying to post pics. atm but they're not uploading properly so please contact me and I'll send them.
If interested pm or [email protected]
Thanks for looking.
engine
turbosmart external wastegate pro-gate 45 $450
custom intercooler pipe with r33 gtr nissan bov 14483-05U00 $70
k&n mushroom filter RX-3900-1 + filter adaptor for subaru $60
justjap coolingpro intercooler 2.5" 600x300x76 (new) $120
r33 gtst front engine cross member $60
r34 gtst air box + intake pipe + recirculation pipe (no snorkel) $120
r33 gtst oem side mount intercooler + piping $100
nismo 6 x 740cc injectors 16600-RR544 (side-feed for r33 rb25/sr20) $500
nismo fuel pressure regulator (new) 22670-RR580 $160
nismo mounting bushes 11320-RSR40 (gearbox) 2 x 11220-RSR40 (engine) (new) $450
nismo thermostat 21200-RS580 (new) $160
r33 gtst rb25det racepace engine, arias forged pistons, gtr rods, n1 water/oil pumps, nismo bearings, machined/honed/prepped (never installed since rebuild) (excellent) $4000
r33 gtst gearbox + cross member $1100
r33 gtst/r34 gtt high energy 7.5 litre capacity sump (baffled for circuit use) (new) $700
r34 gts rear wheel hubs + brakes $150
r34 gts rear cradle $200
r34 gts lsd diff + driveshafts $200
suspension
r34 gtt dms blue 50mm coilover suspension (height/bump/rebound adjustable) (needs coilover tops) $2000
r34 gtt tein ra coilover suspension 10kg front/8kg rear + spare 4kg and 5kg rear springs + custom dustboots (aluminum body) (height/combined bump/rebound adjustable) (excellent) $2500
r33 gtst/r34 gtt 20mm front + 24mm rear adjustable whiteline swaybars (painted black) $350
r33/r34 rear camber + toe pillow ball arms + dust boots (painted black) $150
electrical
hks speed limit defencer type I with packaging 4502-RA002 (remove oem 180km/h limit r32/r33/r34/s13 and other makes) $170
r33 gtst ecu/engine loom $30
r33 gtst auto dash 47000km $30
r34 gtr v-spec rear computers + yaw sensor (unknown working conditon) $80
body
r34 gtr bonnet + hinges + latch (has minor damage but repairable) $500
r34 gtr tail-lights white (excellent) $400
r31 sedan head-lights (left + right) $50
https://www.sau.com.au/forums/topic/275509-r33-gtstr34-gtt-parts-for-sale/
can you send pics to [email protected] of:
1. custom intercooler pipe with r33 gtr nissan bov 14483-05U00 $70
2. r33 gtst/r34 gtt 20mm front + 24mm rear adjustable whiteline swaybars (painted black) $350
is price neg? where abouts melb?
  • 5 months later...
  • 4 weeks later...
hey buddy, cant PM at this time..
just wondering what condition the r33 gearbox is? any crunching? smooth changes? any problems?
also, what are the nismo engine mounts off? are you willing to seperate the nismo gearbox mount?
im very keen. located in sydney but im heading to melbourne in a few days.. PM me your number and ill SMS you. cheers
  • 1 month later...
  • 3 weeks later...
is the r34 gt-t air box the same size as the r33 gts-t air box? only really after the bottom part.. Also, dont suppose the cooling pro FMIC is the return flow style with the piping is it?
  • 2 years later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
