Hey Guys, have got a few things for sale, will keep adding to the list as i find more stuff
All this stuff to suit RB26DETT, all brand new
ARP Main Studs $225 inc Freight SOLD
ARP rod Bolts $75 inc freight SOLD
ACL Race Series Main bearings Std Size $110 inc Freight
ACL race series Conrod bearings Std Size $55 inc freight SOLD
R33 GTR Crank, brand new $900 plus Freight
All this stuff still in boxes
More stuff
RB26DETT Block with main girdle/cradle: Has been hot tank cleaned, bored out to 87mm, decked a fraction to tidy up the face of the block. has had the mains girdle/cradle fitted and checked the tunnels for out of round/out of spec(Needs welch plugs fitted). $900 plus freight
Venolia 87mm forged pistons to suit RB26DETT, Brand new in box, with Nissan Genuine rings ready for fitting. All ciclips/gudgen pins etc there as well. $1000 inc freight
WILL SELL THE BLOCK, CRANK AND PISTONS AS A PACKAGE FOR $2500 PLUS FREIGHT IF ANY1 IS INTERESTED
STD AFMx3 $20 each SOLD
R32 GTR Crank Angle Sensor $50 1 SOLD, still have 1 more
6x Coil packs $70
ABS Module $120
R32 GTR Steering Rack with tie rod ends $150 SOLD
R32 GTR Clutch slave Cylinder $40
Clutch Master Cylinder $50
Brake Booster and Slave cylinder $150
A/C condensor $50
STD R32 GTR BOV $130
A/C Fan(Fan that sits in front of condensor that also switches on when engine gets too hot) $50
R32 GTR Bonnet Catch $80
Front wheel speed sensors $50 each
Rear Seat(No rips, bit dirty and faded though) $30
Passenger Seat(No Rips) $150
LH Door(White and complete) $250
Bare steering column $20
Glovebox Lid $10
Tailights(White Surrounds) $60 each or $100 pair
STD Fuel Pump $100
Drivers Side Headlight $100
Front propellor shaft $50 SOLD
Starter Motor $50
Another 6 coil packs $70
Coil pack resistor $40 SOLD
Rear window $50
Quarter windows $60 each or $100 pair sold pending payment
Front Crossmember $100
Tailshaft $80 sold
ALL PRICES ARE EXCLUDING FREIGHT
Michael for questions 0438911374
Thanks
More stuff:
ATS Twin plate clutch, half worn, good clutch, HANDLED MY 320kw@WHEELS GTR VERY WELL, EVEN AT 7800RPM LAUNCHES $500
Pair of Garrett 2560-5 turbos, good condition, less than 10000kms old, 1 turbo perfect, other 1 has tiny little bit of shaft play, is rated in HPI magazines top 20 turbos list. Direct bolt on replacement of factory turbos. Come with wastegate actuaters, NO DUMPS though $1200
HKS chipped ECU $50
Veilside Chipped ECU $50
Air filters with the Metal brackets that bolt directly onto AFM $50 pair
STD Turbo dump pipes(pipes that bolt directly onto turbos) $50 pair
Pair of cam/rocker covers(come with the screws that hold it down) $80
Thanks guys, also: still wrecking white R32 GTR, heap of bits sold but still some bits etc on there
i know you dont have one posted up but you wouldn't happen to have a gtr boot and spoiler in white would you?
Also what condition are the coilpacks in??
Thankyou
Aren't the Crankshafts superceded to the R34 crank for some time now? Where'd you find a new R33 crank?
Sorry mate, It must be a R34 crank, when i ordered it from nissan brand new they said that the R32 crank was no longer made, the part number for 32 and 33 were the same, i dont think he checked if the 34 part number was the same as well but knowing nissan it must be the same. Thanks for the knowledge
Thankyou
Sorry mate, sold the boot and rear spoiler a few weeks ago.
As far as i know mate, all the coil packs are fine, pulled 1 set out of my 110000km gtr and replaced with the super spark, nothing wrong with the coil packs, just wanted an upgrade and to spend money.
The other set came in a 32 gtr i bought that had been crashed, car started and drove fine, was only running standard boost though
Cheers,
Michael
