my car is apparently stock. after going in your car i can sorta hear your turbo boosting, in my car, its loud as hell! its possible mine is already different. maybe failing in japan
but yes, im happy to chuck the boost gauge on my car for a looksee, i actually wouldnt mind chucking it on the dyno - when the cash allows.
  • Replies 80
There's a dyno day next weekend at Auto Tech and i'm going to put my car up to see if it's boosting over 14 psi with the new front pipes.
Oooohhhhhh :happy:
Forgot about that coming up. I might have to see if I can make that as it will be interesting to see the effect of the new exhaust.
Only drama is I haven't done a oil change for about 5000km. It is due soon. and no time this week to do it.
I would offer to let you try mine on you car but at 2 hours to fit it, It is not coming off in a hurry.
I have a spare gauge at home if you want to check it out.....its also for sale at a very cheap price if you want it.
The only answer is to stick it on a dyno and see what you get. :D
I recon the boost gauge that the RS has is maybe not that accuarte. As you said, it only goes to 1 bar (11.6psi) and this is too low to show the level we are seeing from all the ARX.
I'll have to talk Iain into putting one on his car to see what his car gets. His car is still stock so it will be a good test.
I will be interested to see what my car pulls after the new exhaust goes on this week. :happy:
Actually, 1bar is 14.5psi which is around what you were getting yes?
Also, it would make sense as you said that Jet's gauge was reading 1-2psi high which would take it to around the 14psi mark.
Can't imagine that Nissan would put an inaccurate boost gauge in a car as standard.
Local or JDM exhaust?
My OE turbo with original exhaust was loud as hell as well (from the first day).
Sounded like a Jet taking off and turned heads quite a often.
nah dont worry, when funds allow ill be buying an EBC. i just bought the rear half of a JDM cat-back exhaust tonight ;)
Which?
I saw that there was a Legalis going on IM for a pretty good price (there was also the Freeway/Dolphin cat-back with the de-cat front pipe available).
LOL..... If
You keep telling us that the gauge does not work! LOL That makes a pretty crap gauge to me.
Local. Same guy that did Jetwrecks but aiming for a little quieter.
lol. Yeah it did stop working. Then out of the blue it started again... but then stopped.
Oh well, easy come easy go.
Never said anything regarding the build, just saying that I couldn't imagine Nissan putting in a gauge that read incorrectly, even if it only worked for 100,000kms. :happy:
the exhaust is whats left of houdinis exhaust that he has removed. ill get the rest made up locally to the cat. and do the rest when i get the cash!
i cant remember the brand. but its what i was looking for!
might do one on the fiat too if the mrs lets me :happy:
Apexi N1.
I'd love to go to a dyno day. It's a mystery to me what my car makes at the wheels or otherwise. Far as I know it's got an Apexi air pod and a fairly loud blow off valve matched to my exhaust which has the large front cat and a tiny middle cat and then the free flowing twin pipes. No resonators or anything.
I have no idea if it's got any other mods but I have to say it goes like S*#t off achrome shovel and if it's 206kw's then look out when I start to up the ante because it's going to scare the crap out of me!
I'll have to get someone else to watch the gauge while I'm driving to see what boost it shows because I haven't been game to look down while flooring it ;).
My factory guage also stops working - but its intermittent. As far as I know it may not be the guage thats faulty. When we say its faulty we dont mean that it gives a slightly faulty reading. Its either working or it isn't (ie. it just sits on full negative boost - when it sits on anything else, including zero - then it is definitely working). So yes you can trust the factory guage - mine is exactly the same - reads 0.8 bar.
Also, to touch on what was discussed earlier - I believe the 14psi limit was "discovered" on the rb's so not sure if the same applies to the vq25det. The limit isn't actually the pressure, its the heat. The ceramic can only take a certain amount of heat. Not sure if pressure relates exactly to heat or whether other factors would be involved as well? ie. on a different engine/configuration the same pressure may generate more heat or it may generate less??
Another thing is that when you're measuring boost on the dyno, where are you reading the boost pressure from? Are you measuring manifold pressure or turbo boost pressure? The RB's had a nipple on the side of the motor specifically for reading the boost level, but as far as I know the VQ doesn't have one. I believe the boost reading may be higher or lower depending on where you're reading it from. Or I could be talking utter crap... ??
However I think the boost level we're interested in is the same one that the factory guage is reporting - which is 11.6psi. Note that the boost sensor on the VQ25DET is located just before the throttle body - not sure if thats where the factory guage is reading it from though - I presume this sensor provides the boost level to the ecu primarily but maybe it is also connected to the boost guage in the cabin?
With the talk about these ceramic exhaust wheels... It is not the itself wheel failing, they are usually fine..
What happens is that when they get get too hot from being over boosted beyond their design limits, the glue holding them onto the shaft fails, and so the wheel falls off, and end up in the cat... This may ping off bits of the turbine. Also the fitment of the plastic intake wheel as on the RB25DET, not sure what it is on the VQ25DET, is not on it's own a bad thing. The plastic wheel is light, and so is able to spin up faster than a metal one, therefore boosting more quickly than a steel wheel equiped turbo.
And if you want to see a ceramic turbo that really hates to be boosted above design specs, speak to the JZZ30 2.5TT Soarer guys, and they have two of them failing...
the compressor wheel is most certainly metal on an M35 turbo. i have seen andys one to confirm.
i cant remember exactly, andy you can confirm this, but i think the turbine is bolted to the shaft, not glued, as is the compressor. but i dont have the auction pics on me to be sure.
It is in the boot of the car and too cold and wet to get but from memory there is a bolt on either end of the shaft keeping the impella's in place.
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
