Im selling a full set of 4 Falken V04 R comp tires
Size is 285/35R18
They were scrubbed at a recent oran park practice day and only did a handful of laps. There is approx 70% tread remaining.
They managed to hold down a RWD GTR and produce consistant 1min16 laps around the GP circuit.
The tire is a discontinued model and im not sure if they were even sold locally. These were imported.
The size WILL fit under a stock R32 GTR front AND rear on 9.5 or 10 inch rims.
Only reason im selling them is I usually run full slicks in a much wider size and I may as well sell these off while they still have good tread left and are worth using on someone's car.
I want $600 pick up and im FIRM on the price.
If no one wants to pay that im not fussed ill leave them on the rims and use them up at practice days.
Located in Sydney would rather pick up as I dont have time to organise freight etc.
Edited by Risking
https://www.sau.com.au/forums/topic/275613-falken-tires/
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
