Posting this stuff on behalf of a mate. Please DON'T PM ME about this gear, just email the address below. Cheers
R33 calipers and rotors
R32 GTR rear Spoiler
R32 GTR front lower lip
R32 GTR rear craddle (can seperate, has gtr diff and alluminium craddle bushes)
R32 GTR Nizmo height adjustable shocks and springs
One piece tail shaft to fit between 33 gearbox and 32 rear end
Apexi N1 exhaust from dump pipe back
R32 tail lights
APEXI GT spec intercooler
R32 GTR fuel pump
RB25det engine (has done approx 30,000km)
Another RB25det with head and inlet only $1500
To4r turbo kit (has HKS cast manifold with twin external wasgates) can seperate
OS Giken Twin plate clutch, only done 3,000km
Please email MattR (click here) with questions and offers
"Not sure what else till I start to pull everything down. Am open to serious prices, no harm in asking though"
"Most of the things wont be available for about two weeks when I sort out eveything else"
Cheers - DON'T PM me please!! Contact Matty direct by email.
https://www.sau.com.au/forums/topic/27563-r32gtr-and-r33-bits/
Dude I sent an email to the above address regarding the R32 GTR lower lip. It was bounced back - incorrect address.
Could you please ask your friend to email me:
[email protected]
with details of the condition etc.
Thanks,
Richard
Originally posted by Nightcrawler
sorry mmmgtir, I just realised there was a typo in the addie. Anyone who has emailed Matt please try again .... sorry
Hey Nightcrawler,
That address still isn't working :(
If you could forward on my address re: the lower lip that would be great.
Thanks,
Richard
Yeah I am signed up try [email protected]
lower lip 350 couple of scratches
fuel pump 300
the exhaust will fit a 32gtst thats what I had it on, 700
any other questions just ask
The t04r was on a 32gtst with rb25, it has hks cast manifold and twin external wastegates, I can sell seperatly if you want. looking for 3500 for the whole set up, so let me know if you only want the turbo. Cheers Matt
Hey fatz can do just the turbo for 3000 then you can get a manifold made up to suit.
BAO2ME can do the clutch for 1500 only done 2000kms
morboost havent got digi but looks like a gtr style intercooler
core size 600by270by80
How Much For the Cooler and Wot r the dimensions?
Would u prefer an SA buyer?
Sorry to hear about your car matt that would of been sweet to see it in Speed Mag.
And this is wot was from your car huh? So i'd be guessin it would already be white like the Spoiler etc.?
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
