just decided to put on my leatherette seat covers on today properly and I've taken off the original factory skins off the backseat and passenger seat ... complete pain in the ass because they were COMPLETELY glued on to the foam underneath, so I've lost 2-3 mm of foam in about 30-40% of the surface...
Anyway .. few questions ..for those that do this sort of stuff
1) What sort of glue should I use to glue on my leatherette seat covers on to the foam? Something that won't burn/destroy the foam or dry too quickly while I'm putting it on and tightening it etc.
2) is there any sort of 'spray on' foam that you can buy so that I can fix up the seat foam where I've torn off bits ? Something that can be easily applied and spread and that will dry and connect with the factory foam
Thanks all.. gonna glue the rears on tommorow (still gotta tighten it with zipties around the edges too) but I've pretty much decided to take the front seats to a pro as they're impossible to separate the top and bottom half of the seat so it's a total PITA to put the front covers on..
https://www.sau.com.au/forums/topic/275631-factory-seat-covers-glued-on/
oh yeah and the installation instructions that I got from the leatherette supplier are for an R33 and I was told they'd be the same pretty much ...not even close, totally different seats and the R34 skins are NOT glued on (except inside the seams)
has anyone installed the leatherette seat covers from Max (proseat) on an R34? How the hell are you supposed to pull the zip ties through the foam when it compresses as soon as you punch a hole through? Also what are the zip ties supposed to hold on to on the rear side when the R34 has no bars at back of the foam in the middle sections (only around the frame) Anyone ???
these leatherette seat covers are suppose to go over the original upholestery if these are the ones that im thinking of!!!!
+1 I never looked into them myself, just from pictures I saw on here.
I assumed they just layed them over the original upholstery, although the pictures did look like a tight fit
friend did them to hes 34 and he just sliped them on over the original skins didnt take anything off
Ive just spent the better part of the afternoon doing the rear bottom half ..gonna do the rar top half tommorow and I'd done. It won't be perfect but it sure as shit looks a lot better than a slip-on cover .. looks almost factory.
I'll get the front seats done professionally as they're a bit harder and I want those looking perfect (will probably ask for them to be glued on to avoid any creases etc). All in all ...the R34 leatherettes from Max/Proseat are a total pain in the ass to DIY if you do it properly .. best to let pros do it imo.
On that note ..ther other place "ultimate seat interiors" or something like that, which sells the same leatherette covers has a better design IMO with all the threads provided so you can just pull them through the foam and tighten ..beats screwing around with zip ties (headache and a half when you need almost 50 zip ties just for rear seats..)
that's my handy work ... took ages to finish. Not too shabby for an amateur and a lot of improvisation hey? But yeah, I'm letting a pro do the front seats because I don't want any of those air bubbles/creases on my fronts so I'll ask him to glue them on so they look like factory skins.
the R34 stock skins are completely glued on which is a pain in the ass and the proseat trims use zipties which is another pita .. if you have an R32/33 and use ultimate auto trim ones I don't think it'd be nearly as difficult to do these, lots of peeps have done them
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
