R33 Gtr - Is This Rust Common? (hard To Explain - Pics Attached!)
Hey guys and girls,
I have a bit of rust in a section which is a bit hard to explain. its near the bottom front window plastic and under the side guard. (i've taken a few pics)
It hasnt gotten any worse in the close to 3 years i have owned her and only looks like surface rust. I've been meaning to sand it back, seal and recoat with some touch up paint for a while but havent got around to it yet.
Anyway, is this a common problem? Does anyone else have it? :(
Any info or advice would be appreciated.
Cheers!
Edited by KR4-GTR
Just a couple of Qs...
It looks as if there's been some fixed-up panel damage > re-weld does it not?
It looks like surface rust only; but is there any bubbling especially if you press on it?
Have the corners of the panel bolts been chamfered as if the panel's been taken off?
Does water sit there after rain or wash?
Does the moulding at the base of the windscreen need replacing?
btw, surface rust can lead to 'cancer'
if its stabilised for past 3 years why worry about it - for peace of mind a quick fix is to get a spray can of fish oil and spray the discoloured area this seals and prevents against any rust - will kill any rust if it is rust - done !
Touche'... that is what I am going to do until one day I can get a respray!
I think you will find its not corrosion in the usual sense - I think its that the finish colour has been applied very thinly over the etch prime in out of place areas when the body is painted at the factory - you see the same discolouration in various places in some Jap (and other country) cars e.g. inside where intrusion bars are fitted in doors , in hard to get to places on the body panels where front bar is fitted etc - its normal , just like orange peel finish was normal on outer underside edges of US made cars some years ago
  TENSE said:
where can one purchase this fish oil stuff from? do they come in them sprayable cans?
repco supacheap ..........everywhere - about $6-8 usual larger size spray can
when it dries fully it is usually clear - you could spray paint over it if necessary
yeah my series 2 gtst has the eaxact same surface rust..... just how the buggers are.... i'd only really worry about rust if you see it bubbleing and going down deep..... usually first place serious rust starts on our imports is under the wheel arches where the japs throw salt on the icy roads to reduce the slipperyness of the roads.....
hey ya'll just been doing some reading on the various treatments of rust ... apparently fishoil is good for preventing any new rust but it won't get rid of any existing stuff plus it doesn't penetrate existing rust which could lead to more rust
Apparently a product called 'Penetrol' available from Bunnings actually penetrates rust deep and takes away the Oxygen and stops any further rust from forming .. apparently don't even need to clean the rust spots up before applying this stuff. Anyone used it before ?
  • 3 years later...
I've got alittle bit of this surface rust starting both sides, Do not like looking at it. Cars mint other then this, So would like to fix it.
How would I go about fixing it. It looks simple enough to do myself, Taking side skirts,front fenders and front bar off is the only fear I have, Then sand it body filler if needed then paint it, And make it look beautifull again, Has anyone had this and fixed it. Did you go to panel beater or DIY it?
Or is going this far not necessary, it just looks sh#t
Edited by dyl33
The Conversion Paint is easily brushed on with a quality long hair brush. It does not affect the colour of your existing paint, because it dries clear. Within an hour the difference is there before your eyes.
The Fish Oil I have is in an aerosol can.
This process stopped any more rusting of an Alfa Romeo in its tracks. Any automotive paint shop has it - but I don't know about Repco/Auto1/Supercheap
Hmmm, I usually treat rusts with the usual wire brushing for removal, then zinc spray (lightly), then spray paint over. No oils of any kind or rust converters. Opinions in this gents? Never knew about fish oil until reading through SAU forums, got to learn boatloads, especially from the build section.
I had the same problem and although it wasnt progressing over a few years i still decided to fix it. Just remove the arch, wire brush and sand it back as far as u can to really clean it up. Its usually just surface rust with some pitting. Then apply some rust converter (which youll get from supercheap etc.), give that the recommended time to penetrate and then u should be able to blend the colour or ive just sprayed the area matt black because it cant be seen unless u look. Thatll hold it off for quite awhile. Ive had no issues since.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
