Ive mounted a rb25det neo into my r32gts, also done a top mount conversion along with a bit inlet manifold and 90mm throttle body, and new 630cc injectors, also mounted new splitfire packs and iridium plugs. also mounted a greddy Emu, also walbro fuel pump and removed the control unit for standard fuel pump and replaced it with a relay.
the car runs fine except most times, happens alot then the car is warm, when im stopping and lights and such the car dies, sometimes the rev goes down to 1k idle then drops down and engine stalls, it can go into idle if i help with the pedal a bit, but then the idle is around 600rpm, and then when im give it a small gas it dies, but if i give more gas it coughs and then goes up and runs fine. if im looking at the log in the Emu, when i get the car idling the ignition jumps around a lot, could this be just the TPS thats in wrong place, tried to adjust it but not sure where it should, at one part i didnt get any idle at all, at another part i got very weird rev, jumped from like 1200 and 800 up and down, apart from this the car runs fine when im driving, only doing like 1bar atm, but nothing seems unstable with boost and vacums and such
also have Hks Ssqv and ive tighted the spring a bit.
ive also mounted the R34GTT instument cluster to get the speedo working, and ive checked for codes using the engine check light, but ive connected different parts to get all codes away
https://www.sau.com.au/forums/topic/275640-low-rev-problems/
Are you sure it's not the Blow off valve?
When you're on the gas heading to a set of lights, and the light goes red, you push the clutch in and get off the gas onto the brake. The blow off valve opens up and lets out air that the AFM has already measured as being in the system, so the ECU is still injecting gas into the engine, making it run extremely rich and causing the stalling issues as you've said.
AFM reversion can also cause similar symptoms. The flutter you may hear when the BOV sounds is actually air flowing back out through the compressor, flowing the wrong way through the AFM. This upsets the AFM readings and can lead to the same stalling issue.
My 2cents anyway, best of luck with it! :(
just had everything apart and checked and fixed before i put all together, the IAC valve is now located under the inlet så cant be taken out without removing the engine...
is there a posibility that you have to adjust the idle screw when you change manifold?
i hav the same problem s1 r33... i changed spark plugs and coil packs are fine, cleaned IAC valve and AFM and ran injector cleaner but still keeps stalling when the car is warm n comes to a stop :) i dunno wat to do. would it be o2 sensor or ecu (i think its been remapped or sumting rev limiter kicks in only at 8500rpm) or anything else :S
What? I took mine out without having to remove my engine, i just unbolted the intake pipe where the throttlebody it to get easier access. unplug a few pipes and its real easy to change
just but as i said ive changed intake manifold for an aftermarket one so i can have a topmount turbo, this new large intake doesnt have have the intake part for the idle valve in the back cause there is no space, so its fitted on the underside pointing down
Not really across what kind of tuning ability the Greddy EMU gives you, can you run a map trace on it?
If so, replicate the conditions it'll stall under watching the map trace and note the cells it'll hover around when it stumbles and stalls (Should be the very left column) and then lean the shit out of them..
To stop the stalling on my engine (T04Z rb26 with a power fc) I have to run these so the ecu thinks it's running an AFR of around 25:1
I dare say that'll fix your problem..
EDIT: The stock ecu runs +15deg ignition at 650 - 900rpm, so as long as your ecu is still stock and the Greddy EMU isn't set to intercept the ignition if you're seeing +15deg ignition at idle your timing will be correct :)
Edited by aphid
Hmm okay heres a weird one for you all.
Ive checked and double checked most things now, till i tried stopping the vacum pipes to different sensors, and when i stopped the vacum to the standard mapsensor the car suddenly gets good idling?
what i know the standard Map sensor only have mission to check for over boost?
next question, can i just plug the hose going to the map sensor and run like that? im using both Emu and Apexi AVC to control everything, or will the standard ECU go into fail safe if it doesnt get readin from the standard map sensor in some time?
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
