I think the TB48 all by itself is a better option without a different head... i think you can stroke them to 5litres too??? i just never thought about one of them in lil ol silvia. big engines.
dammit. i have two rb30's here and now i want a Tb48!!!!! lol.
seems there is support for them too http://www.briancrower.com/makes/nissan/tb48.shtml
Theres a stroker kit already available from Brian Crower ex usa. Takes it out to 5.1 litres.
The existing twin cam head looks like a derivative of the 25 neo head to me. I am guessing all the potential is already there for big valve and port job etc.
yeh...billet alloy block would be fricken cool....lol billet titanium block would be even cooler :blink:
I get a hard on thinking about this stuff :):):)
No shit billet alloy block would be f**king sick, I think RIPS in NZ has hinted at billet alloy blocks before (I read is a thread somewhere on the UK forums).
Sainty's can do you an alloy block but not much good for anything else but drag racing as they have no water jackets. They do an external oil feed rail to feed each bearing journal.
An aftermarket VQ38 block maybe in the pipeline for a PRO FX drag car soon. The rules state an OEM cylinder head or block must be used so if built it will wear factory R35 GTR heads, a billet block, run twin HKS T51R SPL turbo's, drink methanol and be good for 2000hp+.
Definately something that will put a scare into the 2JZ camp.
Edited by DiRTgarage
Wow, that sounds pretty insane, with a Vipec V88 I would hope Paul!!!
Possibly a stupid question... is it possible to manufacture a billet block with water jackets?
of course. but the only reason for a billet block is to get massive HP. massive HP is only needed in drag racing and drag racing doesn't require water cooling because the whole thing is over in less than 8 seconds.
you could get a billet block for circut but really a track car with too much HP to handle is not much good to anyone. you can only use as much power as you can put down.
I investigated the RD28 when researching my RB26 stroker engine build. I have source a service manual in PDF format if anyone wants me to email them a copy, just PM me.
The basic engine specs are 85 bore, 83 stroke, 2826cc. Yes they have oil squirters. Con rod length is 140mm (close to SR20). This means the block is about 20mm taller than an RB25/26. It wouldnt be a stretch to throw an RB30 crank with some SR20 rods and RB30 pistons into one of these and have a 3lt with out the massively tall block of the RB30, and still have a respectable 1.6:1 ish rod ratio.
But as has been mentioned here the block is much heavier. I wonder how much of that extra weight is in the deck area of the block too (top heavy), to help contain combustion of the high compression diesal burn without distorting the block. While this all sounds great for a strong engine, but that doenst mean it would be streetable. This added strength and material would reduce cooling efficency of the bores, and as unleadded burns much hotter than diesal that could be a problem. If your goal is 1400+ hp chances are your burning methanol though, so cooling wont be an issue for you.
I think the costs of converting an RD block with its gains vs sleeving an RB25/26 would be negligible. It costs about $2k to prep a RB26 block for a high power build and fit with tall liners for open deck stroker. If you want "block reliability" above 1000 hp just use better sleeves.
or go to U-pull it and rip out an RB30e check it out and if no good pull another out and pay 80bucks for a block like i'v done twice now.
sleeve it if you want but probably no need when you can just refresh the bores in the usual manners. build it as strong as you like. perfect square ratio.
drag racing then you could have it grout filled or leave it be and enjoy the extra torque. i don't see the big deal with harmonics, only as good as your balance and balancer.
then the only issue is how strong your rods are. as obviously the longer the stroke the higher the piston speed at the same RPM. Not really an issue with forged rods.
anyway sorry i'v drifted OT again :P
I would love to make one just for the sake of making it, obviously money would be a big hold up, that 90million would have helped alot haha....the whole 'cool' factor is overwhelming in itself, plus having the added benefit of making the engine so much stronger and efficient in many ways is just awesome....you could incorporate as many changes as you want.... The engineering work in it is amazing, painfull at the start of the project no doubt, but just amazing!
Look at some you tube videos of 5 axis cnc's making billet alloy engine blocks...there are some very trick ones on there, v8 and w 16s :sick:
Look at some you tube videos of 5 axis cnc's making billet alloy engine blocks...there are some very trick ones on there, v8 and w 16s :rofl:
You are spot on, it is just dead cool!!! I work in an engineering office and when I go visit suppliers and machinist workshops I can watch the CNC machines go on for ages. Especially when they are machining alloy and rippin' into it with big cutters really fast!
I think it needs to be done, maybe just hand a machinist a N1 RB26 block and say "make one out of alloy". Material along would be at least $5-7k.
I'll snap some photos and sonic test the bores in this RD28 over the weekend. I have to start machining it then anyway.
There is an aluminium block coming soon for RB's, RB30 height, RB26 sump pattern, Darton sleeves etc. It sounds very impressive and a lot of work has gone into it. The block is cast, not billet. I'd say there will be some news about it in the not to distant future, won't be cheap though.
Cheers!
Finally someone is doing it!
Billet would be very nice, though no doubt this cast one will be machine finished in a CNC after and will look almost as good! Whether its as strong or not is another thing.
would you think something like 5-8k for it would be a reasonable price? Or is the thinking alot more? say 10K+? Whats your definition of not cheap?
Cheers!
If it was billet I would have thought material alone would be over $5k, considering it is cast, the initial tooling cost would be huge. Then machining, insertion of sleeves, etc. Not f**king cheap would probably be more accurate!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
