hey just wanted to get an opinion of what u think i should an can do to my r33gtst with $2000.00.. has got greddy bov, hks pod, 3'' exaust from dump back an is boosted to 12psi already..! was thinking of frontmount an dump.. uping boost to 15psi.. i can get that done for around $1500.00.. so still got alittle to play with untill such time.. what do u think? dont want to do all that much to it but..!??? should that give me a good power gain..?
https://www.sau.com.au/forums/topic/275677-new-mods/
adding a dump pipe won't increase the boost unless it is a poor design and doesn't alloy the wastegate to flow properly.
unless you have an aftermarket ecu you won't be able to run 15psi anyway, although you would gain power from doing it, but you may find your turbo doesn't last very long before it goes on a diet (and the exhaust wheel comes off the turbo and makes friends with your catalytic converter)
if a dump pipe is costing you $1500, i really suggest you find a new place to shop unless you get a shag every night for a week from a really hot chick with it. just get a cheap split dump pipe for about $100. i had one on my 33 and it worked fine.
i would also get a fmic kit, especially if you are running 12psi through the stock one. the stock cooler will suffer heat soak after only a few hard accelerations and basically won't be doing much cooling after that.
https://www.sau.com.au/forums/topic/275677-new-mods/#findComment-4669810
nah..! that price includes the dump,r33 front mount and fitted an a service..! not to bad.. cheap. think ill keep the 12psi but.. dont want to kill the turbo.. yet!
https://www.sau.com.au/forums/topic/275677-new-mods/#findComment-4670098
$2k?
I would spend 600 on a stage 2 advanced driving course and 1400 on a set of track tyres. you've already got everything else you need to go quick in the car
u dont think i need a front mount an dump pipe to give that little extra..?
https://www.sau.com.au/forums/topic/275677-new-mods/#findComment-4670107
you do NEED a front mount. as mad082 mentioned earlier that the stock cooler will be suffering from heat soak.
get the dump pipe.
go get a nistune done as well and that will keep you happy for the time being.
yer i think that is the go for sure.. do u think that will give me close to 200rwkw..? thats really all iam aiming for off this car.?
https://www.sau.com.au/forums/topic/275677-new-mods/#findComment-4670312
the issue with the stock turbo is the ceramic exhaust wheel. when they are highflowed they usually have a steel wheel put on (as where it sits is made larger so needs a larger wheel). the limit to what you can run then is then down to mods and what pressure it stops making power, but would be well above 15psi
https://www.sau.com.au/forums/topic/275677-new-mods/#findComment-4673653
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
